Old 12-16-2006, 09:27 PM   #1
In theory this resistorreduces the signal voltage from the MAF sensor, as a result of which the ECU will adjust the amount of fuel being sprayed into the engine.
BUT... Most modern cars including the Yaris have "learning" ECUs that can detect this change in the input voltage (only one variable is being changed, it sees it as an anomaly), and adjusts itself to give the amount of fuel it is supposed to in the first place.
As far as I can see, you'd really need a full ECU rewrite for this to work.
Old 12-17-2006, 12:09 AM   #2
YarisGuy
Drives: 2006 Yaris
Took the words right out of my mouth!
YarisGuy is offline   Reply With Quote
ANOTHER DEALER TRYING TO TRICK ME....I HOPE...YARIS RESALE VALUE BMGYaris General Yaris / Vitz Discussion 16 03-04-2007 03:05 AM
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
