Originally Posted by mojoyaris
Just realized the Tokiko's are short stroke setups and won't work as well with a taller spring setup. With you you guys going for the drop and lower CG, I'm going the opposite route. I'm goint to try out the Koni Yellows.
Thought the Tokico blue are the same exact length as the stock shocks/structs? U mentioned abt the taller springs set-up meaning the stock springs?
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
