Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
scangauge-xgauge-outside temp-works
that is all
That's great! Only I didn't even know it supports outside temp. I'll have to look into it.
07 Yaris RS
Drives: Red 07 Yaris RS Join Date: Jan 2007
Thats nice .. supplying us with the code .. priceless
Yaris lover |
^lol
any other findings we can plug into the scanguage? :P
Audio Junky
i'll have to try this one... i've been just using the Air Intake temp for a rough guess. Sucks that way, often times the AI is off by 10-15F compared to thermometers on bank signs.
#8 | |
yeah, air intake temp is much warmer use the scangauge II web site, go to xgauge commands, use CANSF ambient air. use the latest guide, and nothing that says experimental it is dead-on accurate and takes data from the probe for the a/c unit. if you have A/C your yaris will have the temp probe. this is nice to know when you are driving in freezing rain or wet roads close to freezing. |
Has anyone else tried this on a pre-2010? It doesn't work on my 09, nor on Crashy, as neither of their ECMs support the OBD PID "01 46".
#10 | |
here is the code I loaded Ambient Air Temperature (F) 07DF0146 04410546 2808 00090005FFD8 AIR Degrees Fahrenheit I haven't tested below zero, to see if it will throw a neg in there.... it only got to 9 degrees at home so far and my Yaris blew me a 7, 8, 9, 11 all the way to work. it is dead-on accurate (my home probe is on the sunny side, my Yaris is downhill from it, hence colder) The other built-in indicator on the scangauge (FIa) Intake air was showing 22-24 deg (not useful data) |
After I tried it (and also tried it directly by CAN bus message to the ECM) I realized that you have a 2010. When I request the list of supported PIDs from the ECM 0146 is masked as an unsupported PID, so I have a feeling that ambient air temp is a new PID for 2010.
#12 | |
can bus data. mine happens to be 'common'. woot. ! all the more reason scangauge > ecometer FYI ha, tried cansf fuel level code, that one doesn't work Last edited by 127.0.0.1; 12-18-2009 at 02:38 PM. |
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
Arg! I was so looking forward to using this till I read further!! (I have a 2009)
#14 |
Audio Junky
eh.... 08 here... wish I had a 2010 tho... the extra air bags would be nice if I get in a wreck.
#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Well, here's the ghetto way. It's worked well since August when I put it in the car.
http://www.yarisworld.com/forums/showthread.php?t=20840
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! | TRD_Yaris | General Yaris / Vitz Discussion | 183 | 02-01-2017 12:18 PM |
| Works bell/Nardi quick release steering wheel setup | blacksandiegovitz | Cosmetic Modifications (Exterior/Interior) | 35 | 09-02-2009 05:52 PM |
| Inlet air temp vs. vehicle speed | LtNoogie | Performance Modifications | 8 | 04-27-2009 12:20 AM |
