Old 12-25-2009, 12:49 PM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Alright guys, i managed to "reduce" the stiffness out from my car. Remember the earlier on "Rear free supension mod"? I shifted up the pivot point of my rear suspension before i did my tokico blue as posted. By shifting the point up, i gain additional stiffness on my rear spring which i can gain slightly more responsive handling and the "extra" steering with the cost of losing the comfort.
I just recently shifted back the pivot point to the stock configuration(lower point). And now BINGO!!!!! My ride feel less "stiff" on the rear for overall comfort and yet still can provide the "super glue" feeling round the corner!! I am falling in love with the BLUEs!!!!!!!!!
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 12-26-2009, 11:51 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
you make an interesting point here. the Fit spring i use in the rear was a loose fit when i was using the lower twist beam mount. when i raised that pivot point, the spring fit it very tight, and had to be pry'd out to be removed. now, the Tanabe rear spring was a tight fit with the lower mount, so if you were to raise the rear pivot point, that would compress the spring.
now, does spring preload effect the rear spring rate? i am not sure. you said you noted the rear felt more stiff, but is that an effect on the spring rate of compressing the rear spring or is that "feeling" from the change in suspension geometry? i am not really sure, id love to hear another opinion on this (ie. Loren, Tamago)
so, i looked up this calculator for spring rate: http://www.engineersedge.com/spring_comp_calc_k.htm i changed only 1 variable, and that is the # of ACTIVE coils in the spring. i changed nothing else. using the defaults in the calculator, a change from 10 coils to 8 coils increased spring rate from 18k to 23k. so, what that tells me is this: if you take the DF210 rear spring and compress it (eliminating a certain amount of coils) by raising the rear suspension mounting point, you will increase the rear spring rate by doing so though reduction of the number of coils. how much? no idea, but it certainly SHOULD go up.
another benefit to a free mod!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 12-27-2009, 04:36 AM   #3
evo165
evo165's Avatar
U r correct!! By shifting up the pivot point our rear springs are being compress alot. As we can see from the side of the rear wheel area after the car is release on the ground. The springs is being compress till there's no "gap" between the coil thus will greatly increase our springs rate in the rear.
As mentioned, shifting up the pivot point will greatly compress the springs(higher spring rate) and at the same time, i strongly believe that we are playing with the rear suspension geometry as well. (Eg. roll center & anti squat thingy) Is anybody there who are good with car set-up pls enlighten us...
Tokico HP (blues) Shock/Strut driving impressions. largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 09-09-2010 12:03 AM
Tokico Blues + TRD Springs &Sway Bar after 5k miles regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-17-2009 11:11 PM
Tanabe NF210 + Tokico vs. TRD springs and shocks fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-19-2009 03:42 PM
Tanabe NF210 vs Stock springs tcpty Yaris TS Talk 15 11-12-2009 09:15 AM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
