![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Thanks for the insight HTM. So why would the Teins give more oversteer and the Tigers would give understeer? I just want to make sure I understand things right. My current setup is Tokicos, TigerTec springs and a UR 23mm sway bar. I'm thinking whether or not of switching to Tein S-Techs or not, if there is even much difference between them and the TigerTecs to justify switching springs.
#2 | |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
How much do you find your current set-up in your ride? Do you like them to be more over-steer(increase steering)? If not, it will be good for you to stay as it is. I must say that the Tein S-tech are really stiff over my NF springs but they provide me SO MUCH more of steering which i love it but i really can't take the "super low" form and discomfort due to the high stiffness. In the end i sacrifice the "increased steering" for more "comfort" by putting back my NF springs. It is all about compromise. ![]() Any car with higher spring rate on the front than the rear will provide u more "understeer" characteristic. Where higher spring rate on the rear than the front will provide you more "oversteer" characteristic. Hope the above will help you to make better decision.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 09:08 AM |
| >>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< | TWM Performance | TWM Performance | 0 | 12-24-2009 10:21 AM |
| Tein or Sprint Performance?? | youngxlos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-17-2009 10:33 PM |
| 07+ Yaris Tein Springs/Suspension | CorSport | CorSport | 0 | 07-09-2009 01:18 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 05:08 PM |
