Old 12-27-2009, 04:00 PM   #1
Sidicas
Drives: 2010 Toyota Yaris Hatchback
If your bass is dipping into the battery constantly its going to take its toll and wear out faster and then your symptoms are going to progressively worse like what you have now. Maybe try taking it to auto zone to have them load test it for you. They do sell deep cycle batterys there too.
I had this issue with my acura when i was running 2 high powered amps. I went through 3 different batterys within a years time. Finally just went and upgraded my altenator and my battery to a optima. That cured most of my problems.
My thoughts exactly.. These batteries aren't meant to be discharged, if you're running a high power stereo system, don't ever run it with the engine off.. Even discharging lead acid batteries to 70% on a regular basis is not good for them.
Sidicas is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
New headlights CasuaL Cosmetic Modifications (Exterior/Interior) 11 11-24-2009 07:25 AM
Sedan Headlights looklike lexus LS monchito18 Cosmetic Modifications (Exterior/Interior) 2 08-10-2009 07:06 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
