![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
suspension upgrades like springs, coil-overs and shocks won't solve the problem.
Motor mounts help. Best thing to do is to upgrade the A-arm bushings to urethane or spherical bearings. Wheelhop is causeed by rotational movement of the A-arms. The other thing you can do is to make traction bars, this will eliminate wheelhop all together. this is what a traction bar set-up looks like for a fwd car, it links the front control arms to the lower core support..... http://www.full-race.com/catalog/pop...7756e08be3c159 you may even be able to make a Honda set-up work with some fabrication
Ptuning.com |
| electrical problem with car need help badly!! | Adriaan | DIY / Maintenance / Service | 20 | 05-07-2010 12:40 AM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
