Old 06-18-2009, 11:57 PM   #37
enkid
Drives: 07 Yaris Sedan
Driving straight on dry pavement these tires have the same or maybe slightly (very slightly) worse rolling resistance than my old ones at the same pressure, summer/late spring temperatures. After several rainy days over several tanks I can say these tires have much less rolling resistance than the old tires when wet. Rainy days no longer keep me from getting 50MPG. I wonder how they'll be next winter.
enkid is offline   Reply With Quote
Old 06-19-2009, 09:30 AM   #38
aclark246
50 MPG or BUST!
Drives: 2007 Black Yaris Sedan
Hmm that is interesting about the rolling resistance dry/wet but great for rainy days. We sure seem to be having a lot of them over here...
Thanks for the updates enkid!
aclark246 is offline   Reply With Quote
Old 06-19-2009, 09:20 PM   #39
enkid
I'm saying - dry compared to dry, while rolling straight, in mid 60's F average temperatures, the new and old tires have about the same rolling resistance.
Wet compared to wet, in mid 60's F average temperatures, the old tires had a much higher increase in rolling resistance than the new ones do.
Old 06-19-2009, 09:52 PM   #40
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
So how many miles do you now have on the new tires?
roadrunner is offline   Reply With Quote
Old 06-26-2009, 10:26 PM   #41
enkid
Not sure, about 2000 miles give or take a few hundred...
Old 12-18-2009, 08:19 AM   #42
enkid
Winter update.... 15000+ miles, tires at max sidewall (51psi). Good comfortable ride, steering very precise. Rolling resistance a lot better than older tires in cold weather. I guesstimate 5 MPG cold weather improvement for a 45 mile mostly highway trip vs. Eagle GT tires.
Old 12-21-2009, 11:20 PM   #43
enkid
These tires are surprisingly good in the snow...better than I expected.
Old 12-31-2009, 11:23 AM   #44
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I put a set of gfg's traction ta's on my yaris 35lbs and they killed my mpg can hardly get 40 mpg was getting 45 and 46 in warm weather going to buy a set of wheels and some better tires this spring
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 12-31-2009, 01:00 PM   #45
YarisSedan
Drives: 08 Yaris Sedan
Isnt that a really harsh ride running at max sidewall pressure.
Old 01-08-2010, 09:04 AM   #46
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
I notive a HUGE difference between 34psi(what they put in at the tire shop) and 40-42psi(what I inflate them to once I get home). It is not a bad ride, but noticeably more firm.
I could only imagine 50psi must feel like rolling on solid rubber tires with no air needed : )
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 01-08-2010, 10:12 AM   #47
BailOut
Steals terrorist's lunch
BailOut's Avatar
I run anywhere from max sidewall to 60 PSI, and while the ride is definitely more firm than at the door pressure it isn't "harsh" at all. When driving through switchbacks in the mountains 32 PSI would actually allow for sidewall roll, while higher pressures maintain the sidewalls.
- Brian
Share the Road
Old 01-08-2010, 11:26 AM   #48
1stToyota
1stToyota's Avatar
While generating a much smaller footprint, fact...tires at the factory recommended pressures, that's where the nice cushy ride and shorter stopping distances come into play, and actually safer handling; good alternatives to just getting maximum fuel economy, imo.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
