#19 |
I have owned so many deep dish wheels and owned those exact wheels in the stock silver finish with flat caps and can tell you that to fit on a yaris, you will need atleast 3.5 degrees of camber along with rolling the fender. Unless you want to wear a mouthpiece when you drive...then you might be able to get away with less camber but you'll still have to pull/roll. Looks good though...especially on white.
#20 |
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
Is stretching the sidewall like that safe?
#21 |
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Hey i would go -3 with a rolled fender and you should be good, cause you want it prefectly flush with the lip. This is going to be awesome!
You think your Yaris is low and fitted LOLzzzzz |
#22 |
![]() Drives: '08 yaris hatch Join Date: Dec 2009
walter, that fitment will look sweet! you can't let the vdub guys have all the fun!
#23 |
Whatever you end up with I'm sure it will look sick bro.
#24 |
der Zeck
#25 |
#26 |
der Zeck
stretching tires puts extra stress on the sidewall, and tires are not meant to be seated at that steep of an angle. If you over inflate to keep the tire seated you put even more stress on the sidewalls, and if you under inflate to keep the stress down on the sidewall, you run the risk of unseating the bead.
Over all forcing something way beyond it's normal limit is usually a bad idea
#27 |
Stretched tires lol
#28 |
seriously though I would never stretch tires for the following reasons
Tires distorted due to being fitted to too wide a rim requiring much higher inflation pressures to prevent excessive wear on the edges of the tread surface Rough choppy ride due to higher inflation requirements Likelyhood of actually having the tire coming off the bead if impacted Higher wear rate on suspension components Higher wear rate on wheel bearings Poor directional stability due to wrong offset being used |
#29 |
This actually originated on euro cars due to laws passed that only allowed a certain width of tire tread on vehicles. So people started running ridiculously wide wheels with the same size tires to "rebel" against the new standards.
#30 |
Never heard of any of those complaints from anybody running stretched tires. I don't find the ride quality any different and suspension components are doing just fine. The biggest problem I can see is unseating the bead. Aside from that, I think most of the rest of the complaints against stretched tires don't really hold up very well.
#31 |
Shut your fricken suck!!!
GDF's: God Damn Flushaholics!
#32 | |
phxdemon, state your source for all the claims in post #28 -- then we can have a real, informed discussion on the matter.
#33 | |
Start another Oil Thread!
common sense would tell you that a stretched tire is not as safe as a tire on the correct width wheel:
1. grip is reduced 2. tire will be much hotter during operation (you are placing more load on the sidewalls, because they're designed to support weight on a "vertical" plane, not leaned over to the side. because the sidewall of the tire is now being stressed outside of it's safety zone, the extra movement of the sidewall during motion will create much more heat 3. more heat = less speed capability. if the tire is rated to 118mph on a stock wheel, give it about 80mph stretched. 4. when you stretch a tire, you are creating a "cup" in the center of the tread. this leaves the "corners" of the tires pushing more onto the road unless the pressures are raised internally. 5. raising the internal pressure of the tire to prevent weird wear patterns decreases contact patch, and increases growth during the hot cycle (see boyle's law) common sense people. stretching is for poseurs and show queens. would you trust your life to half a comdom? no? you'd rather have a whole condom in place during intercourse? but a half a condom looks so much more "flush"!!
you nailed it sir.
#34 | ||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
-Jen <3 ![]() Quote:
#35 | |
JDM Fred
people in touge and drift have been stretching there tires for plenty of years and you don't see them complaining. Drifting requires maximum grip out of a tire and I see lots of pro's stretching. Although most of those people actually care a lot about show, but to each their own. No one said you had to stretch tamango. I give the op credit just for trying it |
#36 |
Stretching a small tire on a wide rim correctly is very hard too do...If done properly it will not fail and looks amazing, and to go flush it must be done because the lip of the wheel has to line up with the fender edge to be considered "Flush", there can be no poke at all. They actually make tires that are made to pretty much be stretched and are used for negative camber. Alot of VW owners use them....
| Test drove Rio5, Fit, and Yaris all today | kmf123kmf | New YARIS Purchase Forum | 16 | 10-02-2009 08:48 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 03:14 AM |
| Zefoxe - Photo Scavenger Hunt | Zefoxe | Photo-Video-Media Gallery | 0 | 03-02-2009 11:23 PM |
| thewifesyaris - photo scavenger hunt | thewifesyaris | Photo-Video-Media Gallery | 0 | 03-01-2009 07:02 PM |
