Old 01-09-2010, 06:27 AM   #1
teejayy
Drives: Toyota Yaris SR 5dr Hatchback
yaris2010RS, if you gave me your Amplifier's name I could answer this more accurately.
Essentially a Line Output Converter converts high-voltage speaker-level signals from your Head Unit down to an acceptable pre-amp level signal ideal for Amplifiers. You then connect the Line Output Converter to an appropriate Amplifier using RCA patch cables. If you purchase a Line Output Converter with a remote trigger, which is advisable, it will turn on your Amplifier when it detects an output on your factory speaker wires.
Of course if your Amplifier has built in Speaker-Level Imputs (can be called High-Level Imputs) you can use these instead of going down the Line Output Conveter route. Essentially the Amplifier has built-in circuitry which uses the Low Impedance, High-Level Output from factory speaker wire as an Imput. The Amplifier uses signal sensing so when the Head Unit is turned on and an audio signal is on the speaker wire, the Amplifier "sees" the audio signal and turns on, eliminating the need for a separate remote lead from the head unit.
If your Amplifier doesn't have Speaker-Level Imputs then a Line Output Converter is an ideal solution. There are many Line Output Converters on the market, Crutchfield sell a Scosche SLC4 which is an ideal solution if your are aiming to use a multi channel amplifier. I have also heard good things about David Navone products, and I know that some of his products do include Remote Triggers.
Once you've got the Amplifier working off the standard Head Unit, the rest of the install is a piece of cake!
If you feel that information is not accurate please do correct me, but I have answered this to the best of my ability.
Good Luck with the install!
teejayy is offline   Reply With Quote
Old 01-09-2010, 02:29 PM   #2
yaris2010RS
yaris2010RS's Avatar
wow, thanks so much. i haven't gotten anything yet, i wanted to do a mock up to know exactly how to hook it up with stock HU. i wanna build my box and sink it into the trunk before i start with amps and wiring.
one otherthing, is it really that important to have the fuse within a foot of the battery or can i have it right by the amp?
Old 01-09-2010, 02:58 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
LOC means Level output converter... the voltage levels is the issue, deck outputs high voltage to the speakers... but pre-amps meant to go to an amplifier are low voltage lines... the LOC converts high voltage signal to a low voltage signal.
Even if you get a high quality LOC.... you're still limited to the quality of the deck... which I personally don't think is that great. Lots of issues with reliability, and I question its SQ performance as well.
Feeler: Pioneer AVH-6850DVD 2-DIN head unit + extras eTiMaGo Items for Sale by private party 19 08-07-2009 09:49 AM
Fitting amplifier to Yaris head unit nish1979 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2009 06:18 AM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
Factory Head Unit Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 6 05-11-2007 07:55 PM
