Old 01-10-2010, 02:25 PM   #1
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Originally Posted by Sodium Duck View Post
6-12, I'm a little lost on. Can anyone help? I really want to maintain this vehicle properly and learn to do it myself. Would anyone add something else to the list, or is that enough. I just figured I would do as much as possible since I'm going to be on, under, and around the car all day tomorrow.
Don'y be so lazy, supmet! The inspections aren't pointless. Depending on the environment you drive in, or the possibility of defective parts, there is good reason to inspect the listed areas. Looking at something only takes a few minutes.
These are all good questions. I was about to enumerate all the requirements, but there's a downloadable shop manual available that explains it much better than I could. Go to this web site and download the "Maintenance" section and anything else that you might need:
http://etimago.com/yaris/repairmanual/
In short, (but read the manual above):
6. (read the manual).
7. Yes.
8. (read the manual), need to remove the wheels, and rear drums. Can be done while rotating tires.
9. (read the manual), and Yes.
10. Yes.
11. Yes. (read the manual)
12. Everything you can see. I have personally found bolts that had been missed being tightened from the factory.
Reddog99 is offline   Reply With Quote
Toyota Maintenance at Dealership? fmicle DIY / Maintenance / Service 18 03-17-2012 11:27 AM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
60K Mile Maintenance Pattycake DIY / Maintenance / Service 20 11-17-2009 02:34 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
