Old 01-13-2010, 12:30 PM   #1
Cutie Pie #2
Drives: 2014 Honda CR-V LX
Originally Posted by b_hickman11 View Post
Maybe something is wrong with your Scan Gauge.
I could see that, but the inside temp.for the heat goes up and down also, to the point that it has a cold feel to it, and the coolant level is just below the max line, well anyway I'm going to get it look at on Friday, I will keep you posted on what happens.
Cutie Pie #2 is offline   Reply With Quote
Old 01-13-2010, 12:42 PM   #2
127.0.0.1
plus an odd sound in engine....possible big air bubble in water lines
Old 01-13-2010, 02:29 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Take the radiator cap off with the engine cold. If it's not full to the cap with the engine cold, it doesn't matter what's in the coolant tank. The air bubble will allow for expansion of the coolant as it heats, it won't push any excess out into the recovery tank, and it won't make a sufficient vacuum to pull coolant out of the tank into the radiator. The system needs to start out with the radiator, water jacket and lines very nearly purged of all air to function properly.
Old 01-14-2010, 09:30 AM   #4
Cutie Pie #2
I took radiator cap off and it was full there, well I'm taking it in tomorrow to get it checked out. I have change jobs and are alot closer to home, I only drive about 10 mins to work, so this maybe the reason why the temperature is doing what it's doing I just thought of that.
Old 01-14-2010, 09:50 AM   #5
127.0.0.1
nope.
it should behave. it should get warm and stay warm. jumping around is not normal.
a car temp will -feel- different on corners as cold/warm air masses inside the cabin get thrown around,
but the electronics reporting a difference ? that is some internal problem
Old 01-14-2010, 09:52 AM   #6
Yaris Hilton
Smile
Just another thought: When you're feeling waves of cool air with the heat running, are you going around a curve or corner? Even at moderate cornering forces, the distribution of layered warm and cool air in the cabin shifts markedly.
Old 01-14-2010, 10:04 AM   #7
Cutie Pie #2
Yeah that might be it too, but the temperature on my scan gauge will go up to about 186 where it should be but then when I either let of the gas or brake I see the temperature go slowly back to 168 and sometimes even down to 140 and then when I give it gas it goes back up to 190 then it is fine,but today I noticed it went down to 168 when I put it park and felt the temp. inside the car go down a little. And this was when the car was warmed up. The car had never done anything like this before, but I did have a longer commute before.
Old 01-14-2010, 06:26 PM   #8
b_hickman11
Drives: 08 Sedan
Is this when the engine is cold or hot?
Old 01-14-2010, 06:40 PM   #9
Cutie Pie #2
After 10 minute drive to work.
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Question about the Engine Overheating LED captainm27 DIY / Maintenance / Service 1 07-21-2009 09:09 PM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 12:20 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
