#1 | |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
It's sexy and cheap lol.
Give Me Resonance
and gets the job done...cant really go leaving that one out. just bc somethings sexy and cheap doesn't mean its safe....cough.
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
#3 | |
Audio Junky
Skin effect is straight up propaganda... at the amperage levels you are talking about, the entire conductor is saturated regardless of strand count. Would love to see the results of resistance test on 15ft of 1/0awg car audio cable vs that of 1/0awg welding cable... It'd take some might expensive equipment to measure any difference from the two electrically... and who knows, the welding cable might just win. Like I said... welding cable is UL certified, it actually has to meet standards. Cheap? Car audio wire is usually 50% to 100% more than welding cable of the same awg. The real reason you buy it is cause it's sexy. |
#4 | |
http://en.wikipedia.org/wiki/Transformer#Cores As for skin effect, it is a very real thing, I promise. We use air/foam core cables at work because it helps eliminate it. The skin effect only starts happening at much higher frequencies than audio, so unless someone is using power cable to transmit RF, skin effect isn't going to be happening on the power cable.
| How to remove the OEM Front speaker | charleschia1986 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 09-30-2009 09:12 AM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| HELP! I changed a speaker while the car was running and now I hear nothing! | dccurrent | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 04-08-2009 06:44 PM |
