Old 01-13-2010, 09:54 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by goku87 View Post
higher strand # helps reduce eddy currents, as minimal as they may be.
It's sexy and cheap lol.
not sure how eddy currents are involved as that is talking about magnetic fields... maybe you are thinking about the "skin effect".
Skin effect is straight up propaganda... at the amperage levels you are talking about, the entire conductor is saturated regardless of strand count.
Would love to see the results of resistance test on 15ft of 1/0awg car audio cable vs that of 1/0awg welding cable... It'd take some might expensive equipment to measure any difference from the two electrically... and who knows, the welding cable might just win. Like I said... welding cable is UL certified, it actually has to meet standards.
Cheap? Car audio wire is usually 50% to 100% more than welding cable of the same awg. The real reason you buy it is cause it's sexy.
Old 01-13-2010, 11:26 PM   #2
goku87
goku87's Avatar
Drives: Black HB
The separate conductors act similar the laminated cores of transformers to help prevent eddy currents.
http://en.wikipedia.org/wiki/Transformer#Cores
As for skin effect, it is a very real thing, I promise. We use air/foam core cables at work because it helps eliminate it. The skin effect only starts happening at much higher frequencies than audio, so unless someone is using power cable to transmit RF, skin effect isn't going to be happening on the power cable.
goku87 is offline   Reply With Quote
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
How to remove the OEM Front speaker charleschia1986 In Car Entertainment + Electronics (audio / video / alarm) 11 09-30-2009 09:12 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
HELP! I changed a speaker while the car was running and now I hear nothing! dccurrent In Car Entertainment + Electronics (audio / video / alarm) 12 04-08-2009 06:44 PM
