| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
#181 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Sweet. Sorry if this was already answered way back.
#182 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
#183 | |
#184 |
Yes I agree with you, if you can add it I think it would be a good option. Also you mentioned you could remove the speed limiter, again some people might be interested in that also.
#185 |
![]() Drives: 07 blazing blue hatch Join Date: Jan 2010
Hi all,
New to the forum here. CTScott - this one cool project you are undertaking. It is great enough to make me join the forum! Count me in for one of these. Thanks for your great work. |
#186 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Looking good CTScott!
With these tap splices, will it be easy to put back the old unit, in case I would sell the car?
#187 |
#188 |
#189 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
... and it probably wouldn't work on other cars unless you plan on getting another Yaris if you sold your current one.
#190 |
![]() Drives: 2010 Hatchback Join Date: Jan 2010
After reading this thread it appears the YarGauge will not work on my 2010 3-dr manual, which has a tach on the left.
#191 |
That's correct, since the clock is not a separate module, like on the tachless ones. I am trying to figure out where the YarGauge could be integrated to have the OEM look for tach equipped liftbacks and sedans.
#192 |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
Oh that sucks. I was totally going to buy one but didn't know the new ones came with a tach lol.
#193 |
#194 |
Still want me to take some pics of the inside of my cluster? I have one with a tach - just tell me what you need a pic of and I can do it tonight.
#195 | |
I obviously could mount it in a small enclosure, that you can put anywhere (like the scangauge), but that diminishes its value versus products like scangauge. |
#196 | |
One question though: since we can't replace the clock module, is hooking it up going to be more difficult? IE: are more spliced required? |
#197 | |
Ground, constant power, switched power, and possibly dimmer. To install the proto on my 09 w/out tach, I only had to tap one wire (outside temp sensor), as I realized that the two can bus connections could be made to two test points on the back of the cluster. |
#198 |
Does the '09 5-door LB have a built in temp. sensor? When I installed my CIPA rear-view mirror w/ compass, temp. and map lights, I had to install a temp. sensor. I clipped that to the bottom-most grill on the front bumper.
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
