I'm thinking of retrofitting those Bosch mini H3 projectors into the fog light housing and removing the shield for my high beams (HID lows would always stay on). Do you have any opinion on that paul?
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
I've heard from the folks on Hidplanet that the Bosch mini H3's make only so-so fogs, and terrible hi-beams. The problem is, in removing the shield entirely, the light cant be focused at all and by the time the scattered light is through the projector lens, it's so dispersed that it's practically unusable. That's why bi-xenon projectors only raise the shield, to move the cutoff upward and allow more light to be focused in a forward pattern, with any projector if you remove the shield completely, the light output pattern tends to suck. Everyone on Hidplanet is fairly unanimous that if you use single-xenon low beam, you should go with reflectored halogen hi-beam.
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| "OEM" fog lights from ebay | drell42 | Cosmetic Modifications (Exterior/Interior) | 5 | 07-28-2006 09:21 AM |
| Liftback Fog Lights on eBay | Chris07LB | General Yaris / Vitz Discussion | 8 | 07-24-2006 07:06 AM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
| Echo fog lights | drell42 | Cosmetic Modifications (Exterior/Interior) | 1 | 05-26-2006 08:37 PM |
