Old 01-16-2010, 08:34 AM   #1
Originally Posted by Fazulka View Post
It has an automatic transmission.
OK, so that means it's not the lack of the clutch cruise control switch.
Reading your initial post, it sounds like everything is correctly wired. The one thing you don't mention is where you grabbed the ground for the other leg of the switches. Make sure that you have a good solid ground.
Also. posting some pictures would help.
Old 01-16-2010, 11:00 AM   #2
Fazulka
Drives: 2007 Yaris 4dr Sedan Base
Ok, I'll take some pictures this afternoon. I have one ground from a self tapping screw that is under the cover your knees would bump if you pulled the drivers seat too far forward. I am using it as ground for 2 other things, the remote start / keyless entry module and power door locks. Is that an ok place? Where would be better?
Fazulka is offline   Reply With Quote
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
