Old 01-21-2010, 01:11 AM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Ah... I had a bad feeling after removing part of the wheel well earlier. So should I just extend the harness that comes with the markers and tap splice into the green turn signal wires in the fuse box? Or would it be easier to splice into the red(?) wire that connects to the amber bulb at the back of each headlight.
... Or could there be an even easier way that won't make me want to tear my hair out?
Focus_Sh1ft is offline   Reply With Quote
Old 01-22-2010, 01:32 AM   #2
Focus_Sh1ft
So one wire in the harness to tap the green headlight wire, and the other to attach to the chassis for grounding, right?
Old 01-22-2010, 06:14 AM   #3
Correct.
Old 01-20-2010, 07:53 PM   #4
MadMax
MadMax's Avatar
Don't use double-sided tape, use a sealant such as a silicone waterproof caulk...
Old 01-21-2010, 03:12 AM   #5
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Why don't you just get the Micro Image LED side mirrors? At least you won't need to drill holes and it will look professional
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 01-21-2010, 01:58 PM   #6
Focus_Sh1ft
Oh I'll be getting those too in due time..
It's probably better it all goes down this way because when I get those I really would prefer to rewire the markers to come on and stay on when I turn the headlights on.
Old 01-21-2010, 02:06 PM   #7
gosh, my apologies, I didn't get that you had a sedan either. Very sorry for confusing you!
Old 01-21-2010, 11:02 PM   #8
Focus_Sh1ft
Haha, it's ok.
Some advice on the exact wiring would still be quite appreciated.
Old 01-21-2010, 11:33 PM   #9
Haha, it's ok.
The Green wire on the turn signal bulb connector is your + and any chassis ground point is your -.
JDM Vitz RS Side Mirror with LED Signal Light AlainMikli Cosmetic Modifications (Exterior/Interior) 35 11-18-2013 08:47 AM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
LED Side Mirror from Micro Image? IsLNdbOi DIY / Maintenance / Service 0 12-21-2009 05:08 AM
side marker lights yrsdrgn Cosmetic Modifications (Exterior/Interior) 154 07-10-2009 02:55 PM
Side Marker Lights Stoln General Yaris / Vitz Discussion 1 07-04-2007 02:44 PM
