Drives: 2007 Yaris Sedan Join Date: Jan 2010
keyless entry with tachometer
Have a 2007 Yaris Sedan with power windows/doors and a tachometer. The factory accessory keyless entry can not be installed on this car, because of the tachometer. Has anyone heard/found out why?
That is totally bogus. There is nothing different about a car with a tach vs one without from the standpoint of factory keyless. If you want me to 100% verify that, let me know the part number on your car's ECM (under the hood, against the firewall on the passenger side).
Roadrunner Jr.
I've got factory keyless entry on my 07 S sedan...same options plus CC and power mirrors. I doubt the options have much to do with the tach and the operation of the keyless entry.
It's going to be replaced with an Autopage alarm here in a few weeks though.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#4 | ||
OEM Alarm on Yaris w/ Tachometer
VIP Alarm V3 Quote:
This part is very important, "If you purchase the power package you get a tachometer and a DIMMING DOME LIGHT, which is what causes the problem." Toyota will not install this alarm into a Yaris with a tachometer because Toyota the Manufacture says NO. Toyota will install a factory alarm system (VIP) into any Yaris that doesn't have a tachometer. Hope this helps. |
#5 | |
Interesting. The solution is to use the door courtesy switch inputs to the ECM rather than the ILE output from the ECM as the door closed/ajar feed to the VIP. |
#6 | |
So it sounds like if I move the door ajar wires from the alarm systems factory designated location (ILE?) to another location (ECM?) that would tell the alarm the doors are closed when they are even if the dome light is still on? Hopefully I have this concept correct. Thank you for the help CTScott! |
#7 | |
#8 | |
I tried that 1st thing to see if it fixes the issue but it doesn't. I think that it's because of a capacitor or something that stores a small charge once all the doors are close it "leaks" the stored power to the dome light for about 7 seconds. So that the customer will get a nice light that auto dims off.
Even if you turn off the light at the switch power is still being stored and leaked out every time the doors are open and shut. |
![]() ![]() Drives: 2008 yaris sedan Join Date: Jan 2010
wow interesting read. i have a question coz i've been planning on putting a keyless entry on my sedan and i have the power package / tachometer. i'll be getting a cheap viper keyless entry from best buy will it still give me an error even though i let the professional install it?
#11 | |
i thought we can encounter the same problem with the oem ones. thanks CTScott for clearing that up.
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| Factory Keyless Entry | LR118 | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 11-12-2008 07:46 AM |
| keyless entry? / security? | mem | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 10-22-2008 01:29 AM |
| Aftermarket Keyless Entry - How does it affect the Warranty? | aerock19 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-07-2007 02:11 PM |
| I want keyless entry!!! | Lillydot | General Yaris / Vitz Discussion | 7 | 03-20-2007 10:46 PM |
