Old 02-01-2010, 10:31 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Or, maybe I should drive my Xterra though the showroom and tell them my gas pedal stuck...
That would rock! I'm kinda shocked we haven't heard of at least 1 person doing something like this to get revenge on someone, its the perfect excuse.
Colin Chapman disciple
Old 02-02-2010, 08:49 AM   #2
markitect
Drives: Yaris
At least these posts show that it's not all just driver stupidity, we ARE dealing with a real problem with a physical part, not just a floor mat -- so can we just drop that?
http://www.autoblog.com/2010/02/01/u...river-reporte/
Now you have heard!
markitect is offline   Reply With Quote
Old 01-31-2010, 11:58 PM   #3
Hershey
I feel for those who have to slam on the brakes and then put it in neutral to glide to side of road . Not all will have these conditions . Better hope no one is close behind them and that an opening will be available to pull to side of road . Could be quite difficult in a 2 > 4 lane interstate at high speeds . Wonder if TOYOTA knows that not everyone will have ideal conditions to stop their vehicle to get to the side of road .
Old 02-01-2010, 07:19 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
http://www.nytimes.com/2010/02/02/bu.../02toyota.html
Old 02-01-2010, 10:24 AM   #5
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Solution
Old 02-01-2010, 12:56 PM   #6
DOMAV
Drives: Yaris 09 T-spirit 1.33
hi can but what is the recall for exactly?? for the gas pedal?
what happen it sticks? thanks i tried to search but couldn't find my answer
DOMAV is offline   Reply With Quote
Old 02-01-2010, 01:16 PM   #7
MadMax
MadMax's Avatar
Yes, the gas pedal. Even though our Yarii don't fall under the recall, I still think it is a great excuse if you get caught speeding!
"Sorry officer, but you know how the gas pedal sticks on these Toyotas!"
Your car is equipped with a unique stopping system called THE BRAKES! When your desire to keep moving ends, employ them to stop/counter that action. Works most every time!
Cheers! M2
Old 02-01-2010, 02:03 PM   #8
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Cheers! M2
LOL! I'll use this excuse if I have too!
Old 02-01-2010, 02:47 PM   #9
Kongo-Otto
He is from Malta so his Yaris should came from TMMF and this means RECALL.
Old 02-01-2010, 02:54 PM   #10
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
How can you speed on Malta? It's a small island... there isn't enough runway to get to such high speeds
No offense, just trying to be funny here
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-01-2010, 04:38 PM   #11
DOMAV
yes is very small but very nice
thanks all for the replies
What does it mean it come form TMMF?
Old 02-01-2010, 01:05 PM   #12
eric81
eric81's Avatar
Drives: Toyota Salesman
The gas pedals, after extreme wear, usually in high heat or high humidity areas, sometimes start to feel sticky (reacting slow and a little harder to push down). Here's how to tell if your car MIGHT have an issue...
1. Get into drivers seat.
2. Without putting the key in the ignition, simply put the gas pesdal all the way down.
3. Release gas pedal as fast as you can, and see if it comes back slower than you are comfortable with. It should take less than 1 second to go back to original position.
If it is sticky or slow, you may have a vehicle that needs this fix.
Pass this on to ALL car owners, as the company that makes those parts for the Toyota's also makes parts for almost all other manufacturers. Toyota is fixing a problem before it becomes a problem. Technically, the part is mostly wearing in cars AFTER they run out of their initial warranty, so they don't HAVE to fix anything. They are just doing the right and moral thing by fixing them. Not to mention they have less problems with their cars than any other manufacturer out there. "There is no best, only better."
eric81 is offline   Reply With Quote
Old 02-01-2010, 10:39 PM   #13
frownonfun
frownonfun's Avatar
lol a coworker asked me if that's gonna be kyle busch's excuse when he wrecks this year. i was amused by the comment.
I crush you like tiny clown car, because you are clown, yes?
Old 02-01-2010, 10:45 PM   #14
goku87
goku87's Avatar
Drives: Black HB
I'm still not understanding how it's the pedal. My money is that it's the ECU.
goku87 is offline   Reply With Quote
Old 02-01-2010, 11:48 PM   #15
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
its not the ECU, they actually explained it. its the spring that helps return the pedal, apparently it gets used up and looses its tension so they are going to insert a shim to compensate and replace the spring
no that is not how it works. it has nothing to do with the spring
the hall effect sensor rubs the magnet (and it really shouldn't... or just barely touch) and when there is the slightest
bit of wear in the pivot the friction increases as the parts slide past each other.
the dealer-added shim maintains the fulcrum point (by wedging against the pedal arm) so the friction in the
sensor is reduced or eliminated throughout the life of the pedal
127.0.0.1 is offline   Reply With Quote
Old 02-02-2010, 12:25 AM   #16
goku87
goku87's Avatar
Drives: Black HB
That and the pedal has two springs anyway.
Old 02-01-2010, 10:51 PM   #17
frownonfun
frownonfun's Avatar
so now it's got nothing to do with floor mats?
Old 02-01-2010, 10:57 PM   #18
frownonfun
frownonfun's Avatar
but don't all vehicles' pedals use springs? and so wouldn't every vehicle be prone to having a spring lose tension over time? isn't that the nature of things... they wear out?
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Toyota Temporarily Suspends Sales of Selected Vehicles redglare45 Off-topic / Other Cars / Everything else Discussions 0 01-26-2010 06:33 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota recalls vehicles over faulty engine Lizardboy General Yaris / Vitz Discussion 1 07-18-2006 07:07 PM
