Old 01-22-2010, 10:31 AM   #1
dreadypeetje
Drives: Toyota Yaris 2001
Here you have pictures of my wire harness, i know, i dont have the connector anymore so i did it this way. Radio and speakers works fine so the problem isnt there :)
Hope this will help you :)
thanks for helping me :)
dreadypeetje is offline   Reply With Quote
Old 01-22-2010, 10:46 AM   #2
OK. The wire colors match what I see in the EWD for the 2001. The unconnected Green is the dimmer, as your friend mentioned. The 2001 Yaris/Echo had the antenna up front, so it doesn't have the antenna amplifier like the later years and 2nd generation do.
So, it sounds like either your antenna connector is not seated properly in the new radio, or the tuner is bad.
Old 01-22-2010, 10:51 AM   #3
dreadypeetje
The antenna wire cant be placed wrong into the radio i think, so the most option is my radio tuner is bad.
MANY thanks to everyone who helped me! I check out for a new radio and post it here when i know more ;)
Thanks!
Old 01-22-2010, 10:56 AM   #4
Thanks!
Not placed wrong - Check to make sure that it is pushed in all of the way.
Old 01-22-2010, 10:58 AM   #5
dreadypeetje
Yup i checked that before, the antenna plug can't deeper in the radio.
aftermarket power lock problem mauiyaris In Car Entertainment + Electronics (audio / video / alarm) 17 08-24-2010 02:40 PM
Problem with Yaris aftermarket parts manufacturers GMKing Performance Modifications 11 09-14-2009 12:08 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
car antenna question mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 6 12-12-2008 01:41 AM
