![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
I think that Toyota should recall Yaris's with ABS to replace the rear wheel speed sensors and the wiring harness. Our Canadian neighbors to the north and those of us in New England and parts north are starting to have problems with corrosion of these parts. The ABS light and brake light come on because of corrosion of the parts and it costs between $400 to $600 per side to fix. If you didn't buy the extended warranty you are out almost 1200 bucks. I called Toyota's customer service line and asked if a fix was in the works and basicly got hung up on. Toyota has become the new GM. Buy the car and we don't want to see you again.
#2 | |
What is 99% of 2? |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
And we shouldn't give any federal fund to California because you want to support all those illegal aliens!
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
#4 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
The issue is the accelerator mechanism (sometimes even if the peddle is not stuck depressed) and/or the programming of the ECU. And the issue is beyond the accellerator and ECU to because cars with a start/stop button show the button as ineffective during such anamolies. |
#6 | |
It's ALL OVER the internet....but here is just one which speaks to the accellerator mechanism....which may be just part of the problem: http://link.brightcove.com/services/...id=64104531001 |
#7 | |
I don't care what AOL says... if its all over, find me a text link ;) |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
Start/Stop Button works flawless. Depending on the car you have to press it for 3 seconds or you have to hit it several times while the engine is running. Of course it does not cut off the engine with a single short hit, because you might hit the button accidentially while driving.
#9 | |
Whenever I have any sort of a problem with any company etc. I always send a registrered letter (siginature required) to outline the problerm, giving them my means of contact. It may be a hassle to get a particular address but, it's well worth it. This never fails to get attention as they can no longer claim they are unaware of the situation and you have legal proof of the situation. |
![]() Drives: 2010 Yaris Join Date: Jan 2010
Thanks RedRide, I think I will write a letter to Toyota and also the local dealer certified return receipt on both outlining what I wrote here and also include the VIN. This is a serious problem that many on this thread may not have experienced, yet, but it is a problem.
Flash news, the other half just called and it did it today but at least was controllable with the manual transmission. Maybe it is just a few vehicles with the problem but it is a problem that needs to be addressed by Toyota. And for Toyota reading this, the mat is way out of the way and is locked down by a factory set of hold downs so it can't move. Which also begs the question as to why Toyota would supply a mat in a vehicle that would cause a pedal jam? |
#11 | |
#12 | |
Mr. 155 and climbing
The interesting part that I found on the whole deal was that why, if I had been to the dealership several times since the TSB, had they not said, "we have a TSB for the ABS and we need to schedule the replacement". When the flammable sound deadening material TSB came out which was pretty cheap in comparison they contacted me right away. Also as a point of reference I was experiencing braking issues building to a regular basis during the winter months until they replaced the parts.
![]() Drives: 2007 YARIS 3 DR HATCHBACK Join Date: Oct 2008
Have you tried a "I'm a dissatisfied Toyota custmer" picket sign in front of a Toyota dealership...this will get thier attention and they can't hang up on you.
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| Toyota Temporarily Suspends Sales of Selected Vehicles | redglare45 | Off-topic / Other Cars / Everything else Discussions | 0 | 01-26-2010 06:33 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota recalls vehicles over faulty engine | Lizardboy | General Yaris / Vitz Discussion | 1 | 07-18-2006 07:07 PM |
