Old 01-24-2010, 03:32 PM   #1
b_hickman11
Drives: 08 Sedan
There have been quite a few threads in the past that discussed this, but here's a Mythbusters style analysis of it (fortunately, minus the large explosion at the end):
Today I am working on the range until empty and fuel level in gallons (or liters) features for my YarGauge project. I drained Crashy's fuel tank and then added 1 gallon (precisely measured with a one gallon laboratory flask) at a time while recording the data values from the analog to digital converter, which I have connected to the fuel level input to the instrument cluster.
I plotted a graph to see how linear (or not) the fuel sender value is in regards to the volume in the tank. From bone dry to the top of the filler pipe, I was able to put in 12.8 gallons. The ADC value stops changing at just over 11 gallons.
So, you can put just shy of two gallons more into the tank than the fuel gauge can measure.
Attachment 31330
This is not only on the Yaris. Every car or truck I have owned has the same "problem" as the Yaris. It's the norm.
b_hickman11 is offline   Reply With Quote
Old 01-24-2010, 03:38 PM   #2
Exactly. Because the level sender is in the tank and the fill pipe is above, this will always be the case. I just thought it was interesting to see the data on where the real cut off is.
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
