Old 01-26-2010, 11:37 AM   #1
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
yoda, i'll help you out w/ install questions for the H4 HID kit from Garm. i think they are awesome and the NorCal members even liked them at last fridays meet. :)
Old 01-26-2010, 03:09 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Same here. The single HID is so easy to install, you can't possible have a problem. Bixenons (hi/lo) are a bit more complex, but still pretty easy, but most everyone tends to find the hi-beams to be unuseable due to the poor pattern from the reflectors. Halogen hi-beams are never focused worth a crap, since the bulbs are piggy-backed, thus off-center. Single HID is easy, cheap, and very effective. Once you use the HID lows, you'll never need a hi-beam.
You will probably need to re-aim your headlights a bit lower to avoid blinding other drivers with your glare. Ideally, you'd retrofit projectors, but that's another story.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
New headlights CasuaL Cosmetic Modifications (Exterior/Interior) 11 11-24-2009 07:25 AM
Blue Tint TinyGiant Cosmetic Modifications (Exterior/Interior) 25 10-17-2009 08:58 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
