Old 01-26-2010, 02:35 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Thanks scott! I have been checking my fuel mileage the old fashioned way, and filling the tank pretty full (to second pump clickoff on slow fill) was wondering how well the evap system can deal with an overfull tank w/o flooding the canister or the purge lines and causing trouble.
TheSilkySmooth is offline   Reply With Quote
Old 01-26-2010, 04:04 PM   #2
The evap vacuum line connects at the top of the filler pipe, so theoretically it will only get wet when you overflow the filler pipe. Although, if the filler pipe is very full (but not overflowing) it is quite possible for the fuel to slosh around enough to get some where it shouldn't be.
Old 01-26-2010, 05:23 PM   #3
kameele
Drives: 2009 Zephyr Blue manual sedan
CT--there's no end to what Crashy can do!! it's nice to know that there is a little more capacity than the spec says. i know nothing of the structure of the gas tank. is there any heel left when the level hits the gas line? That is, any un-useable gas left behind?
kameele is offline   Reply With Quote
Old 01-26-2010, 08:27 PM   #4
For the test, I started with the tank less than half full. I drained it by disconnecting the filler pipe from the tank and using a hand pump to siphon the gas. I drained it until the pump was sucking air and the bottom of the tank had less than 1/4". I started the car to see if it would start and run for a bit and after about 5 minutes I got bored and shut it off and started grabbing my data. The bottom of the tank is flat with a couple of ridges for strength, so I think it still running was due to the well within the sender unit.
Here is what the bottom of the tank looks like. It is basically flat with a small recess where the sender unit sits.
Name:  Tank - Bottom.jpg
Here is a view of the sender unit, looking down into its well where the fuel pump sits. You can see the circle facing the float which is the intake.
Name:  Sender - Bottom.jpg
Old 01-27-2010, 04:24 PM   #5
kameele
So basically, if you run out of gas, the tank is dry.
Old 01-27-2010, 04:34 PM   #6
Very close to dry. When it stops running the bottom of the tank is barely covered.
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
