Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
3DR Hatch utilizes 6.5" speakers up front, and 5.25" speakers in the rear.
Some people have used 6.5" in the rear with the help of a spacer/bracket. If you don't plan on replacing the stock head unit, then I do not suggest getting component systems. Component speakers only come to life when you power them with an external power amplifier. IMHO, it would be sort of a waste to have components powered off the head unit. I suggest looking at 6.5 and 5.25 coaxial speakers which would be affordable and ideal for your current needs. You will need a spacer/bracket for your setup. There's a couple options here: 1 - Get a Scosche SAT-6 bracket. This is a plastic bracket adapter that will allow you install a 6.5" speaker to the front door. 2 - Make your own spacer/bracket adapter. I created a template for spacers for the Hatchback front/rear using 6.5" and 5.25" sizes. Spacer Templates Here: http://www.yarisworld.com/forums/showthread.php?t=1930 You would need to know the mounting diameter of the new speaker, and you would trace that on the spacer template. Cut the template with a bandsaw and router, finish it off with some sanding and a coat of resin/paint you are good to go. If you don't plan on installing the speakers yourself, bring the template to an audio shop and they can fabricate the spacers and install the speakers for you. 3 - Gut the old speakers and use the remaining "frame" as a bracket.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
| Add remote to factory keyless. | imknotright | DIY / Maintenance / Service | 50 | 03-24-2018 12:10 PM |
| factory stickers | casterqc | General Yaris / Vitz Discussion | 16 | 06-21-2007 07:16 AM |
| picture of the back of the factory radio..? | static808 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-10-2006 04:02 PM |
| Source for factory style spoiler?? | imknotright | DIY / Maintenance / Service | 6 | 10-18-2006 01:47 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
