Old 01-28-2010, 12:26 PM   #1
Kal-El
Kal-El's Avatar
don't run this tank dry. If the car stops because of no fuel, you will not be able to get it started again at all, and will have to go get gas. i did it once, trying to see how far I could go on a tank of gas. I've never had a car that just simply refused to start like the Yaris did.
Am I reading this right? You're wondering why the Yaris won't restart after you stall out by running it dry?
Hint: gas powered cars do not run without gas.
Old 01-28-2010, 01:50 PM   #2
I know what he means. On some cars, when they run out, you can restart them, and drive them gently (to keep the last bit of fuel as stationary as possible) a bit until they die again. The way the Yaris' fuel system works you can't - Once it quits, it's done.
Old 01-28-2010, 03:48 PM   #3
127.0.0.1
it will sputter a bit then run good, alerting you that only minutes
remain and you are walking.....
my 4runner does that with <1/2 gallon left
it dies. you stop, wait, start again. in 3 miles it dies again.
start back up, you have 2 miles left, at most
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
