Old 01-28-2010, 01:52 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
@CTScott: Is there a way to measure (in a more precise manner) how much fuel is left in the tank by using an OBD module?
Old 01-28-2010, 02:09 PM   #2
Not really. There isn't an OBD command for fuel level. If we knew the secret Toyota handshake, I could poll the cluster for the fuel level, but that would be the same latent data that the fuel gauge shows.
The problem with doing it by fuel flow is that it is one way. Unless you could also read the flow rate into the tank, you'd still be working down from an approximation.
Old 01-28-2010, 02:24 PM   #3
why would you need a two way? if we would be able to read the fuel flow, then each time you would fuel up you would input the amount into the ucontroller and then just use the fuel flow to calculate the instantaneous fuel level. you could program the ucontroller to always take under consideration whatever is left in the tank and then add this amount to the amount you put in at the gas station. not sure if i'm explaining it clearly
I know what you mean. Actually, the fuel flow rate is calculated from the MAF flow rate (there's not a standard PID for fuel flow), so even that is an approximation.
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
