Old 01-25-2012, 03:04 PM   #1
Nicfin
Nic
Drives: 2008 3-Door Liftback Manual
I may actually have some male and female pins for the under-hood connector, which would allow you to make the connection without splicing.
That would be great! I am not an electrician, but that is sort of what I had in mind. I would gladly pay you for them and any of the other supplies if you were willing. I have looked up some of the parts, but have not made any purchases yet. That makes me feel better about attempting this. Gotta go.
Thanks
Nicfin is offline   Reply With Quote
Old 03-01-2012, 10:21 PM   #2
camry09
Drives: Toyota Yaris 2010
Hey guys, going to bring this back from the dead, i have a 2010 Yaris going to be installing the CC hoping all the wires are there from D3 to Clockspring
My questions is about the stalk wiring
Here is what i picked up today at my local Junk yard ( 08 Scion TC)
My questions is about Wiring Color, i noticed that most of the kits they sell have red and black, so i just want to know where do the pins go according from the Stalk to the Clockspring
thank you in advance
camry09 is offline   Reply With Quote
Old 03-01-2012, 10:33 PM   #3
The orientation of the wires in your first photo is correct for the Yaris. Your horn wire would go in the empty hole under the white/black wire, or if you are plugging the stalk's wires into your clockspring connector, plug the white/black in under your blue horn wire and the black in next to the white/black.
Old 03-02-2012, 08:33 AM   #4
camry09
Thank you, i guess white/black is simply instead of the Red wire.
Old 03-02-2012, 08:37 AM   #5
Actually white/black is instead of black and black is instead of red.
Old 03-06-2012, 04:57 PM   #6
2greek4u
Drives: 2008 5HB LE
Scott, do you by any chance have anymore switches available?
2greek4u is offline   Reply With Quote
Old 03-06-2012, 05:19 PM   #7
Yes.
Old 03-07-2012, 07:04 PM   #8
Nicfin
Nic
I am still in the process of preparing to install the OEM cruise control on my 08 liftback. I was going to use tap splices for the blue and white wires that attach to the plug under the fuse box, which are for the clutch cancel. I was wondering if it was possible to pull the plug and push out the blue and white wire connectors from underneath? If so, I could solder a wire to the very top of each connector without affecting anything else and then reinstall it.
Does anyone know if the little connectors in the plug have a release mechanism? I figured they are not made to remove, but I thought perhaps Scott or someone else might know.
Old 03-07-2012, 08:44 PM   #9
The pins are removable. You have to use a small flat object and slide it along the top edge of the pin to release the plastic locking tab that keeps the pin from sliding out.
Old 03-07-2012, 09:39 PM   #10
Nicfin
Nic
Scott, thanks for the quick reply.
That's good to know. Maybe when I can find the time, I can get it installed.
Old 03-31-2012, 09:18 AM   #11
kadir2538
Drives: yrais 2008 hatchback
my airbag has only one hole.
i do not know how to take it off.
kadir2538 is offline   Reply With Quote
Old 03-31-2012, 01:38 PM   #12
kadir2538
i have turkish 2008 yaris 5 door hatchback.
i cehcked the clutch has switch orijinally.
i think i only need to install the stalk and i need cable for the horn.
the problem that i have is that everyonbe says you gotta take 2 screws off to take off the airbag. but, my car only has one hole and i do not any screws.
help please!
Old 03-31-2012, 08:31 PM   #13
help please!
For 2006-2011 Yaris, only US/Canada Yaris have the cruise control function build into the ECM, so you would need to install a complete aftermarket system to have cruise on yours.
Old 04-04-2012, 09:05 AM   #14
kadir2538
but, i checked it has switch of the cluch. can you tell me what it means?
and cen you explain how to take air bag out. cos it has only one hole.
and there is no any screws in that hole.
Old 04-04-2012, 10:46 AM   #15
On a cruise control equipped one there will be two separate switches on the clutch. The one that is there now, keeps the car from starting unless the clutch is fully depressed.
The definite test to verify if your car can have OEM cruise control is to check the voltage on the ECM pin 40 of connector A21 (my DIY shows the detailed location of that pin). If there is 12 V on that pin with the ignition in the ON position then the ECM supports cruise control. If you do not see 12 V on that pin, then it does not.
Old 04-04-2012, 12:05 PM   #16
kadir2538
MY CLUTCH has two switch one is down the other one is up.
and can you tell me where the ecm is?
Old 04-04-2012, 12:45 PM   #17
Under the hood against the firewall. My DIY in the link below shows where it is, what it looks like, and where the pin is to check:
http://www.yarisworld.com/forums/showthread.php?t=33750
Does your Yaris have steering wheel audio controls?
Old 04-04-2012, 12:56 PM   #18
kadir2538
turkish yaris 2008 cruise control installl
here is the pics.
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
