Old 04-04-2012, 12:50 PM   #1
kadir2538
Drives: yrais 2008 hatchback
my ecu is different.
small socket has 36 pin and big one has more than 60.
and my ecm 2line of pins. yours has 3 line pin.
kadir2538 is offline   Reply With Quote
Old 04-04-2012, 12:51 PM   #2
kadir2538
yes it has audio control.
Old 04-04-2012, 12:54 PM   #3
kadir2538
that is photo of my steering wheels
as you see it on the picture the socket for the cruise control is empty.
and it has just one cable for the airbag.
(would add a pic. but i donot no how to add.)
Old 04-04-2012, 12:57 PM   #4
If you do not have the 1NZ-FE 1.5L engine, then your ECM will be different. Also, only the 1NZ-FE ECM has the built in cruise control function.
Old 04-04-2012, 01:05 PM   #5
kadir2538
my car is d4d
Old 04-05-2012, 05:31 AM   #6
kadir2538
there is no place to install stalk on steering wheel.
Old 04-05-2012, 09:27 AM   #7
That is correct. The 2nd generation D4D definitely did not have the factory cruise control.
Old 04-05-2012, 08:54 AM   #8
kadir2538
miine is
1.4 liter D-4D 90 – 1ND-TV
Old 04-05-2012, 08:58 AM   #9
kadir2538
anyone knows how to close my seatbelt warning sound?
Old 04-15-2012, 10:57 AM   #10
tytrykowski
Drives: 2007 yaris s
2007 yaris cruise control
have a 2007 Yaris Sedan (S) and I want to get cruise control installed, the engine is a 1.5 DOHC 16 valve EFI VVT-i 4 cylinder. Can anyone tell me if I can install original CC as oppsoed to aftermarket?
Tags:
tytrykowski is offline   Reply With Quote
Old 04-15-2012, 10:59 AM   #11
tytrykowski
Tags:
Old 04-15-2012, 02:55 PM   #12
5thhorseman
Drives: 07 yaris sedan polar white
search
Just search cruise control,there is a diy stick on it.
5thhorseman is offline   Reply With Quote
Old 04-15-2012, 03:18 PM   #13
Tags:
Look at my DIY for 06-11 cars, linked on the first page of this thread. I have the stalk and wiring components for sale if you are interested.
Old 04-21-2012, 12:47 AM   #14
xorrbit
Drives: 2007 Yaris 5-door Liftback
Hey everybody,
I'd like to do the switch cruise control mod to my 2007 AT Canadian Yaris. From reading all these threads it looks like I'll need the Indicator Module, 2 Connector D3 pins, and an ECM connector A21 pin. The switches and resistors and such I can source myself. I have a neat idea for the switches themselves and will post some pics once I get it all installed and hooked up :)
BTW Thanks a ton for making these DIY guides and making everything so easymode for someone like me wanting to do this. When I bought my Yaris last year (used) the only thing that I was not happy about was it didn't have cruise control. I couldn't believe when I stumbled across these forums that the ECM had this functionality all along. My daily 25km each way commute isn't that bad but CC will make it oh so much better.
Cheers,
-Andrew
xorrbit is offline   Reply With Quote
Old 04-22-2012, 09:33 AM   #15
Woodsman
Drives: 2010 Yaris Hatchback CE
With the demise of my Yaris (wife wrote it off) I bought a 2011 Matrix. No Yaris available at the time & the rental from insurance running out.
Is this DIY modification possible on the 2011 Matrix?
Woodsman is offline   Reply With Quote
Old 04-22-2012, 09:36 AM   #16
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Hopefully someone will correct me if I'm wrong but I believe the only thing needed on the Matrix (2006 and up I believe) is the stalk. Everything else is pre-wired.
I was considering trading in the Yaris for a Matrix for some time and this was one of my wonders as well.
I do not know about setting up a custom switch alternative to the stalk using the instructions in the thread though.
teddy is offline   Reply With Quote
Old 04-22-2012, 09:48 AM   #17
Woodsman
I hope your right.
The "custom switch" set-up was my intention.
Old 04-22-2012, 10:13 AM   #18
I hope your right.
The Matrix uses the same stalk, so the custom switch method will work as well.
