Old 08-08-2012, 10:04 AM   #1
CodyTheBody
Drives: 2009 Toyota Yaris 4D
Thank again. Worked like a charm! CTScott, u r the man. Thanks bud!
CodyTheBody is offline   Reply With Quote
Old 08-08-2012, 10:06 AM   #2
CodyTheBody
Actually, one more question. Does the "Passenger Air Bag" light near the middle A/C vents always stay on? Or did I screw something up? If there's a problem with the driver air bag, another indicator light will come on in the dashboard cluster next to the speedometer right?
Old 08-08-2012, 11:41 AM   #3
The passenger one is typically always on (Either with airbag on or airbag off being illuminated steady). If it flashes then their is an issue. If you didn't properly connect the steering wheel airbag then the light on the cluster would stay illuminated.
Old 08-08-2012, 04:11 PM   #4
CodyTheBody
Sweet. Thanks man!! You've been a big help! With my alloy rims instead of caps, cruise control and new tint, my non-power Yaris just got upgraded haha
Old 08-20-2012, 02:21 AM   #5
monza
Drives: YRX NCP91R
great info - thanks for everyone who provided photos and information.
I just wanted to hear from anyone in Australia who has added cruise control to their Yaris? From what this thread seems to indicate, the actual ECU on the Australian Yaris' are not able to have cruise control functioning. Therefore am i correct in my assumption that you have to "tap" into a speed control or sensor wire somewhere for Australian Yaris'? Does the instrument panel still have the cruise control indicator on the Australian models?
I'd love to be able to just get this working on my Yaris YRX 2010 (NCP91R) automatic - preferably the kit shown here and not some other random aftermarket kit. Any helpful points would be great.
p.s i did a search on "YARIS cruise control Australia" but didn't find the answers I was looking for.
thanks!
monza is offline   Reply With Quote
Old 01-23-2013, 06:11 AM   #6
Many Japanese market vehicles do not support cruise control. The presence of only two male pins on the steering column end of the D3 connector tells me that your Fielder likely does not.
Old 01-26-2013, 11:32 AM   #7
adamcorey23
Drives: 2011 Yaris S
I have a 2011 Yaris 5 speed MT, No power , Can i still do the cruise control
adamcorey23 is offline   Reply With Quote
Old 01-26-2013, 03:09 PM   #8
Yes you can. You will just need to do an extra piece (adding the connector D3 pins and running the wire from them to the ECM connector).
Old 06-23-2013, 08:32 PM   #9
exidus
Drives: toyota
Dear Scott,
First of all received your wires 2 weeks ago and as I was out of state was only able to install everything yesterday. My car being a Thailand build Camry 2.0 was quite tight under the dashboard. It works like a charm.I am now happily crusing on my Malaysian highways.
Thanks a million Scott for all the info I needed to make this happen....
exidus is offline   Reply With Quote
Old 07-13-2013, 05:00 PM   #10
Jadijkstra2000
Drives: Toyota Yaris 2010
Will this be possible on european toyota yaris 2010?
Jadijkstra2000 is offline   Reply With Quote
Old 07-14-2013, 08:10 AM   #11
Jadijkstra2000
Hmmmm got 89661-0dd90... No idea if it supports cc....
Old 07-26-2013, 11:04 PM   #12
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Doesn't cruise control usually consume more gas than without it? I would probably start falling asleep if I had it on for too long
07liftback is offline   Reply With Quote
Old 07-30-2013, 12:43 AM   #13
jose3sgte
Drives: Yaris Hatch,Celi 3SGTE,GC8
First of all thank you CT Scott for such helpful guide, I did it to my 06 PR spec Yaris and its been working like a charm for 6 months, I just have a question, Can I use a US S spec cluster (2010) to have the indicators working? I just ordered one from ebay.
jose3sgte is offline   Reply With Quote
Old 07-30-2013, 06:01 AM   #14
Unfortunately the indicator will not work unless you also upgrade the ECM to a 2009 or newer one as well.
I offer an indicator module, which can be used with 06-08 Yaris, which lack the cluster indicator. See my cruise control DIY below for more info on it.
Old 07-30-2013, 07:50 AM   #15
jose3sgte
Is the ecu plug n play? Or I have to look for one in particular? (US or PR spec), Thanks
Old 07-30-2013, 08:02 AM   #16
It is plug and play if it is properly matched. You would need a PR spec one. You would also have to match the car's features - Transmission type, engine immobilizer or not, ABS, Traction control, etc.
Old 08-12-2013, 09:26 PM   #17
Bammer
Drives: Yaris
Clear, concise instructions. Close-up pics. Couldn't have completed the job without this info.
Thank-you.
Bammer is offline   Reply With Quote
Old 08-18-2013, 10:07 AM   #18
YarisBasic
Drives: YRX Black 4 doors seden
is anyone know, will the Rostra cc kit work on Australia model (2007) manual sedan,
Thank
Lewis
YarisBasic is offline   Reply With Quote
