Old 10-15-2010, 04:54 PM   #1
magnum23
Drives: Blue,Sedan
Ok, I think I will leave it without the CC indicator because changing the cluster implies problems with the warranty, unless I program the current mileage on the new cluster, I dont know why the ECM support CC and something as simple as the cluster, and having the light indicator don't. If somebody find a way to activate that option I will be glad to try it.
CtScott I'm real thankful to you for all your help, and everybody in this excellent Forum.
I will be around trying some different projects and mods from here.
magnum23 is offline   Reply With Quote
Old 10-15-2010, 05:19 PM   #2
magnum23
Drives: Blue,Sedan
I dont now it thats just it, but I opened up the cluster and it doesnt have any Led soldered in the cruise and set indicators and also in the Abs indicator, If I solder an Led on the board, should it Do the work? If yes where I can pick up a small led or light to test it?
Thanks in advance.
Update:
I found a post where a member mod the led of the cluster, I will be ordering the leds from ther to see if its works.
Old 10-15-2010, 10:23 PM   #3
That's actually my cruise control indicator module:
http://www.yarisworld.com/forums/sho...5&postcount=67
Old 10-16-2010, 01:38 PM   #4
magnum23
Drives: Blue,Sedan
I have another question? I did the wiring (blue wire) directly from the computer to the stalk, even when the stock wire goes from the stalk, somewhere else, does that have something to do with the CC signal don't reaching the cluster? I'm just assuming that maybe is an extra wire in the cluster to get the signal that mine doesn't have.
Old 10-16-2010, 08:55 PM   #5
The CC signal is sent via CAN bus message, so there's nothing wiring related to activate it. We've seen this kind of thing quite a bit, where clusters have a capability, but in a particular area of the world it's not active. Unfortunately, there's no practical way to activate the non-active features.
Old 10-25-2010, 09:06 PM   #6
magnum23
Drives: Blue,Sedan
That's good to know, Scott as soon as you have the ECM repair terminals Im interested in one.
Thanks in advance.
Old 10-25-2010, 10:48 PM   #7
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Sorry to be spamming up this thread, but has anybody done a DIY guide for the OEM stalk on a 07-08 Yaris?
teddy is offline   Reply With Quote
Old 10-25-2010, 11:17 PM   #8
There's not a complete one for 07-08 with the OEM stalk, but it's basically a combination of the 07-08 with the switch method and the 09 with the OEM stalk.
http://www.yarisworld.com/forums/sho...ght=cruise+faq
Old 11-05-2010, 11:32 AM   #9
tunnelpat
Drives: 07 yaris sedan
I installed mine today..it was easy..bought the stalk from ebay for 19.99, the wireing harness and two screws from Toyota for 40.00. Whole thing cost me 70 bucks. :)
tunnelpat is offline   Reply With Quote
Old 11-07-2010, 05:19 AM   #10
MullDoon
Drives: 2010 sedan
installed cruise in my 2010 yaris works great.total cost $14 had to buy 100ft of wire thats all radio shack had.total time of install 1hr with going to store very simple. glad i did some looking around before paying $399 for rostra install. I have 1000 mi on car couldn't do my commute without cruise. thanks
MullDoon is offline   Reply With Quote
Old 12-13-2010, 02:26 PM   #11
ibanezjeepguy
Drives: 2010 Meteorite Liftback
do I need to order this for my 2010 w/ power package.
Toyota OEM Cruise Control Stalk Wire (Required to connect the stalk to the spiral cable, within the steering wheel): 84633-42030
I got the stalk & cover w/ hole in UPS today but no wiring came with the stalk as it does from the dealer.
ibanezjeepguy is offline   Reply With Quote
Old 12-13-2010, 02:28 PM   #12
Yes. The stalk and the wire are separate parts from the dealer.
Old 12-16-2010, 10:39 PM   #13
ibanezjeepguy
forgot to ask, anyone know what size the bolts/screws are that hold the OEM CC Stalk to the car, I think I read it was M5 somewhere ?
Old 12-16-2010, 11:06 PM   #14
M5 x 0.8
Old 12-17-2010, 11:32 PM   #15
ibanezjeepguy
thats great, I had some of these screws laying around from replacing x-clamps on xbox 360. installed the switch and sw back cover tonight, very quick install, if it weren't so dark it probably would've taken half the time!
just a note to future installers, I could not bare fist grip a torx screwdriver to get the airbag screws out. they were in there tight! I had to get my t30 socket on a 1/4" wrench to loosen them. taking off the steering wheel was a breeze, 19mm socket on the nut, held the sw with my legs while yanking the socket wrench did it. did not need a puller like other installers have noted the steering wheel pulled off the shaft effortlessly. removed the ground wire and replaced w/ the wire from the kit I ordered.
done deal. thanks for all the great write-ups
Old 12-28-2010, 09:16 AM   #16
teddy
Ok I have my OEM stalk mounted but do not have the necessary cables hooked up to actually make it work yet.
Is there anyone out there who has done this on an 06-08 that can help me out?
I have the ECM repair terminal and spiral connector repair terminals (thanks scott!). The only part I've figured out is where to connect the spiral connector terminals on the connector D3. I don't know where these connect to on the other end, nor where I use the ECM repair terminal.
I've been using Vince87's DIY guide guide for this part, but unfortunately I really don't know what I'm doing when I get past the plug & play connectors!
Old 12-28-2010, 09:34 AM   #17
This should help with installing the ECM Pin:
http://www.yarisworld.com/forums/sho...hlight=ecm+pin
Old 12-28-2010, 10:04 AM   #18
teddy
That's one more piece of the puzzle... Unfortunately I still don't know where the terminals from D3 connect go to, nor where the ECM connector connects from..
I will definitely be compiling this into a guide when this is done.
