Old 02-22-2011, 10:55 AM   #1
Originally Posted by mbera View Post
Hi guys I just got my yaris - 2011 - 1.3 in south africa. - can I do this mod on her. ?
Thanx
No. Only the US and Canada 1.5L models have cruise control functionality built into the ECM.
Old 02-24-2011, 05:13 AM   #2
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
sirs, just a stupid question...
if we really wanted CC in our yaris, but our ECM was not equipped:
1. can we swapped our ECM with those that have CC already programmed in it? --or --
2. can we use our existing ecm but with some modifications?
our yaris is drive-by-wire, so there must be some other way to do it...
Yaross is offline   Reply With Quote
Old 02-24-2011, 06:35 AM   #3
Only the ECM for the 1.5L engine has the built in cruise control, so if your Yaris has the 1.5, then you could swap in a USDM ECM.
The other option is to use one of the aftermarket cruise control systems. There is one system from Europe for Toyotas and I believe that the Rostra system will work with non-US Yaris.
Old 02-27-2011, 02:30 PM   #4
kimjo
Drives: 2007 HB Yaris
Well we just finished installing the cruise control. It took a total of 2 1/2 hours including the test drive. It probably would have taken less but we triple checked everything. Can't be too careful.
eBay stalk $30 with shipping
Wires from Scott with the correct ends $10 (but really priceless also)
Saving $360 and doing it ourselves. Priceless
Thanks to everyone here on YW for sharing all you learn.
kimjo is offline   Reply With Quote
Old 03-01-2011, 08:00 AM   #5
DSprague
Drives: 2010 Yaris sedan black
Ok, picked up my new 2010 Yaris sedan yesterday with no power package. What Toyota part #s do I need to install factory CC with the stalk on the column? I read through these 9 pages and now my head hurts and I feel confused! Any help would be great.
Thanks
Dan
DSprague is offline   Reply With Quote
Old 03-01-2011, 08:19 AM   #6
Thanks
Dan
Dan,
For your 2010 you should just need the Stalk (84632-34011), stalk wire (84633-02020), and mounting screws(90159-50199 {quantity 2}). If you want the precut hole for the stalk, rather than drilling the plastic cover, you will also need the lower boss (45184-52130-B0).
Old 03-01-2011, 08:34 AM   #7
ibanezjeepguy
Drives: 2010 Meteorite Liftback
http://www.trdsparks.com/displaypart...&parts_id=2306
pretty cheap stalk & wire combo. for the screws just get some from hardware store I believe they're M5 x 0.8 , same as xbox 360 heatsink
ibanezjeepguy is offline   Reply With Quote
Old 03-01-2011, 09:07 AM   #8
Also, I have a couple of the stalks with the wire and the screws for $40 shipped, which is less than half of that price.
Old 03-01-2011, 01:17 PM   #9
DSprague
I'm in, how do I pay you?
Dan
Old 03-01-2011, 02:05 PM   #10
Dan
PM sent.
Old 04-21-2011, 01:49 PM   #11
Midnightsun
Drives: 2006 Yaris RS 5DR White
Hey CTScott, I have been trying to get a hold of you as I would like to purchase this from you. Can you PM me please. Thanks.
Midnightsun is offline   Reply With Quote
Old 04-23-2011, 11:45 AM   #12
Sorry, I've been out of the country SCUBA diving for a week. I just hit you back by PM.
Old 03-01-2011, 09:09 AM   #13
ibanezjeepguy
how long have you had those? I could've used an awesome deal like that last year!
Old 03-01-2011, 10:11 AM   #14
About two months ago a friend of mine got me a few at dealer cost.
Old 03-19-2011, 05:28 AM   #15
CB900F2
Drives: 08 Sedan
Thanks Scott!
Old 03-21-2011, 08:55 PM   #16
CB900F2
Drives: 08 Sedan
Installed the CC on my CND version 2008 Sedan and all went well, I want to give big thanks to every one and especially Scott for all of his great help!
I installed the OEM CC stalk and ran the CC signal line from D3 to AD4, getting to AD4 was not too bad, just trying to work in the small area under the dash was the only challenge. Grounded the GND line from D3 was no issue.
I recommend the up grade to anyone needing CC
Thanks again to Scott for all his great help and supply of connectors.
Old 03-28-2011, 08:57 PM   #17
Aetre
Drives: 2009 3dr Liftback
Hi, all. Newbie with a 2009 3dr liftback automatic and the dumb question of the day:
What parts of this cruise control installation, if any, would void the warranty?
Aetre is offline   Reply With Quote
Old 03-28-2011, 09:41 PM   #18
ibanezjeepguy
none...
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
