Old 03-29-2011, 12:03 PM   #1
Aetre
Drives: 2009 3dr Liftback
Sweet, thanks.
Aetre is offline   Reply With Quote
Old 03-29-2011, 07:47 PM   #2
ibanezjeepguy
Drives: 2010 Meteorite Liftback
as long as you're adding toyota OE parts everything should be fine.... its when you start adding in your own home-brew stuff that things become grey
ibanezjeepguy is offline   Reply With Quote
Old 04-24-2011, 09:01 PM   #3
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Can somebody with the OEM cruise & steering wheel cover please post a picture showing the hole where the stalk comes out? Doesn't even have to be a DIY job, even with it installed from the factory.
I'm thinking about picking up an OEM steering wheel cover with the pre-cut hole. The one I drilled is a bit of an eye sore.. much larger than it needed to be because I drilled it in the wrong spot and had to adjust a few times.
thanks
teddy is offline   Reply With Quote
Old 04-25-2011, 06:13 AM   #4
CB900F2
Drives: 08 Sedan
Teddy and all.. Use the template that comes with these installation instructions for the OEM CC installl.
I’ll take some pictures of mine and will post then shortly...
thanks
Old 04-25-2011, 09:55 AM   #5
teddy
Wish I had that template before I drilled the hole! Found it a few days after it was all done.
I was going in blind essentially. This considered I didn't do that bad, but it's a little rough around the edges.
Old 04-25-2011, 12:19 PM   #6
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Excuse my expletives... but my local dealer quoted me $700 for an aftermarket cruise today...
Guess I will be trying my hand at this DIY.....
SKurj is offline   Reply With Quote
Old 04-25-2011, 12:23 PM   #7
teddy
$700? ouch, though believable if you've got a 2004 Echo. The Yaris uses drive-by-wire so the cruise control is entirely computer controlled. With the Echo they'd need to install mechanical controls to maintain the throttle position.
Mine was just a hair over $500 for the third party Rostra cruise which I had removed in the fall when there was an optional recall.
I don't think this DIY will work for you. If you know what you're doing you could probably find the Rostra kit online far cheaper than the dealer wants but you'll be getting your hands dirty installing it.
Old 04-27-2011, 08:03 PM   #8
CB900F2
Drives: 08 Sedan
Photos of my OEM CC install
Old 04-24-2011, 10:48 PM   #9
hayden
Drives: asd
Well I had a pretty scary experience tonight. I installed cruise control with the OEM stalk a few (I think) months ago and it's worked flawlessly up until tonight. It was humid and raining which I think may have caused it?
Anyway, at first CC wouldn't work at all. I fiddled with the stalk a few times on the drive and eventually it turned on. All was well for a couple minutes, until I starting hearing the engine rev and noticed I was going 90MPH (I set it to about 65). It was like the cruise control stalk was stuck in the up position (it wasn't). It did this several times while also cutting out and not working several times during my 30 minute trip. I was obviously watching it very closely after it happened the first time.
Not sure what the cause could be. I'm guessing a loose wire or something? Anyway, extremely unsafe either way and a big notice to anyone out there to be sure to know what they're doing.
hayden is offline   Reply With Quote
Old 04-24-2011, 10:59 PM   #10
If you have access to a multimeter, with the ignition off, measure the resistance between the two stalk wires with nothing pressed and then again with each switch activated.
Old 04-24-2011, 11:17 PM   #11
hayden
Drives: asd
I'll give it a try tomorrow and let you know, thanks.
Old 04-25-2011, 03:10 PM   #12
liam6200
Drives: 2010 Yaris 1.4d
hi, im from the uk, i have a 2010 yaris 1.4 diesel, would this work on my yaris?
liam6200 is offline   Reply With Quote
Old 04-25-2011, 03:19 PM   #13
No. Only USDM Yaris with the 1.5L engine have the cruise control functionality built into their ECM.
Old 04-25-2011, 03:29 PM   #14
liam6200
ok thanks anyway
Old 04-27-2011, 08:11 PM   #15
teddy
Is that with the OEM steering wheel cover (with the pre-cut hole?) That's specifically what I'm looking for.
Old 04-27-2011, 08:16 PM   #16
CB900F2
Drives: 08 Sedan
Hi Teddy.. That is the OEM steering wheel cover, but I drilled the hole using the template.
Old 04-27-2011, 10:05 PM   #17
Here's a picture of one with the OEM stalk hole.
Old 05-04-2011, 03:39 AM   #18
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Can someone please tell me what the functionality is of the single OEM wire/pin that plugs into the D3 connector on the steering column? I ask because I need to replace this connector but want to know what I'll be unhooking exactly, once removed.
Thanks.
white_rice is offline   Reply With Quote
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
