#19 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
I've got some rattle under the hood from modding the airbox and swapping the throttle body that I can fix easily and will sooner or later...
I have some rattle in the hatch that has been bothering me lately. The rear seat is out, so I can hear it nicely while I'm driving. I'm gonna have to move some stuff around back there and check it out...
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
#20 |
Nearly 60,000 kl. on my sedan and pounding around for the past 45,000 on TRD suspension. Still no rattles, which surprizes me considering road conditions here.
#21 |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
Dasboard +1-
but only over pretty big bumps- otherwise tight for a 12,000 dollar car but only 9K miles- the true test comes at 50K plus miles |
#22 |
TRIM HUNTER
my gt spec SPAGHETTI BAR in the rear seems to be loosening up more and more lately giving me a rattle noise over bumps and such....
#23 |
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
ive got the dash-rattles when going over bumps. solution: turn music louder. :)
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
#24 |
driver's side rear speaker mount/trim panel.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
#25 |
![]() ![]() ![]() Drives: S Flint Mica Join Date: May 2006
Luckily, no rattles yet (Yaris is over 3 years old). Now if this was a tC forum, I would have a major complaint about a hatch rattle.
#26 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Luggage cover on my hatchback rattles sometimes on warm days only it seems. I had the dash pod rattle on cool mornings, but since the dealer had to take the entire dash out to replace the a/c evap. I had the foam kit TSB installed at the same time-fixed, other than a minor trim gap from the foam pushing on it. And yes, I've noticed the same thing with the cup holder rattling if open and no cup in it.
#27 |
Drives: 2010 Yaris LB (Prev: 07 Sedan) Join Date: Mar 2009
I have 0 rattles in my 07. Road noise, yes - but I don't hold that against her. :)
#28 |
![]() ![]() ![]() Drives: 2008 Yaris sedan Join Date: Oct 2008
just the rattles in my head
#29 |
![]() Drives: 2009 3LB Metheorite Join Date: Sep 2009
I have had a seriously annoying rattle that I have not pinpointed yet. It seems to come from the rear of the center console or under the seat; I have taken the console apart thinking it was the hand brake cable or splitter (as it sounds like a steel cable vibrating against metal)... nothing, the wires or cables in the passenger seat mechanism... nothing, the plastic covers over the jack or the body numbering plate, nothing...
I'm seriously thinking about not buying a toyota again and get rid of this one sooner than I'd have liked. |
#30 |
60k and no rattles. I even bent my radiator support (Yaris Amateur Rally, LOL) The only rattles are from loose objects in the boot area like metal rulers and pens.
#31 |
TRIM HUNTER
after getting HVAC TSB done dashboard has been nothing but rattles. im going under the notion that if you take it to a dealer and get a shitty tech then the outcome of his work is shitty....
#32 | |
#33 |
![]() ![]() Drives: 2008 Yaris LB 5M Join Date: Oct 2008
22,000 miles and no rattles from the Yaris itself. Stuff inside it at times, yes.
I finally heard the engine noise talked about in all the reviews. With the windows up, radio off, 5th gear going up an incline at 60 mph I hear the engine!! Makes me all warm and fuzzy knowing it is still running so it doesn't bother me. |
