Old 02-03-2010, 10:41 AM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
^ +1
Your dealer is legit, and correct about alignment. There really isn't anything to adjust on the rear alignment without shims. Your front struts should easily last more than 5 years unless you live on REALLY bad roads or you've run lowering springs on the oem struts, so I wouldn't stress at all about it unless you think the ride is poor. If you do replace them, upgrade to somethign better than stock, even if its autozone stuff.
Old 02-04-2010, 11:34 PM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
How long would OEM struts last on lowering springs in an area with somewhat bad roads and doing semi-monthly track runs?
Front and Rear Suspension nisyota Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-27-2009 01:41 AM
IF i do 16x7 front and 17x7 on rear wheels??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 07-07-2009 07:10 PM
