Old 02-04-2010, 01:09 PM   #1
RedRide
RedRide's Avatar
Somtimes you can indeed go to from 2nd to 1st at about 20mph, somtimes you can't
Just don't force it.
Actuallty, it is the syncros trying to do its job that is preventing it fom easily going into 1st and it is just the nature of them.
They can oly do so much so don't force them as thery are relatively delicate parts. They can last the life of the car if treated with respect.
If your syncros were bad you would hear gears grinding when tring to go into gear if your shafts/gears were not spining in sync.
Before the invention of syncros, shifting was an art forn and you had to manually judge was everthing was in sync. It took some skill.
You would hear a lot of gear grinding at times from inexperienced drivers and people would shout out things like "grind me a pound", etc.
Old 02-04-2010, 01:47 PM   #2
Sidicas
Drives: 2010 Toyota Yaris Hatchback
Haha, that reminded me of that one Star Trek episode where Kirk and Spock are driving that old car.. Classic
Sidicas is offline   Reply With Quote
Old 02-04-2010, 03:11 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
"Rev matching" is an old technique known as "double clutching." Push in the clutch, move the shift lever to neutral. Let the clutch back out. Give the gas pedal a nudge to bring the engine revs up to what it'll be in the lower gear you're shifting into. Push the clutch back in and shift into the lower gear. You don't bang anything, but it's all done quickly. Takes practice.
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
1st Gear Revs... Masteraal General Yaris / Vitz Discussion 9 09-30-2007 10:22 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 02:44 AM
