![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
One way to copy that gauge cluster would be to make a mold and use fiberglass.
Using that pink hardboard insulation used to insulate outside concrete walls and some whittling tools you could get it into the shape you want. Make a plaster mold of the foam and then use fiberglass, carbon fiber or ABS plastic to make the cluster surround. Eventually I am going to go with the Apexi decs tach. It has a small digital readout that you can use with various sensors. I really want a water temp gauge so it will work perfect. I should be able to mount it to the column cover and tip it forward to access the glove box.
ChinoCharles Intake supporter. |
#2 | |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
![]() Oh yeah, and I'm really lazy, so the lead time could be months Myself, I was thinking a steering wheel neck pod for a tachometer, kind of like the Mini Cooper, but that particular dash pod really doesn't look too bad. |
How much does the Apexi gauge go for?
I have my eyes on the AIM-Sports complete standalone dash I'm picking one up for my track car, and may just do a second one in the Yaris for kicks
| Vitz RS TRD Racing | jdgriswald | General Yaris / Vitz Discussion | 12 | 05-13-2010 03:53 AM |
| TRD OR Eibach...i'm confused... | hoahmaru | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 39 | 11-07-2008 09:25 PM |
| 18" TRD wheels | abcando | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 25 | 10-10-2006 01:06 AM |
| Gears | bulldogs2k | Performance Modifications | 17 | 07-26-2006 09:16 PM |
| Toyota's Yaris TRD | VitzBoy | General Yaris / Vitz Discussion | 10 | 07-24-2006 09:10 PM |
