Old 02-07-2010, 08:23 AM   #1
kazama82
Drives: VIOS
thanks scott..will try and measure..if it does have, i can do the wiring as stated.?..will the indicator shows at the meter panel?..
kazama82 is offline   Reply With Quote
Old 02-07-2010, 10:39 AM   #2
If it does have it, then you can do the wiring as above. For the indicator, you can shine a flashlight on the panel to see what indicators are there, and if the cruise ones are.
Old 04-08-2010, 10:56 AM   #3
kazama82
Drives: VIOS
hi scott,
i see this post on opening the ECM. If i dc the battery, how do i measure the 12V?
http://www.yarisworld.com/forums/sho...&highlight=ECM
very very sorry for asking a noob question...i have a DVM with me but dunno which wire/connector i need to measure to make sure my car having cruise control function...hope can get some help ...thanks..
Old 04-08-2010, 11:15 AM   #4
hi scott,
To take the measurement you would need to do so with the battery still connected and the ignition in the on position. For actually doing the wiring I suggest that people disconnect the battery, while doing so.
You can stick a pin through the rubber plug in that pin location of the ECM connector to take the measurement.
Based on others experience, I don't believe that your car's ECM will have the cruise control functionality.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
