Old 02-07-2010, 10:39 AM   #1
Originally Posted by kazama82 View Post
thanks scott..will try and measure..if it does have, i can do the wiring as stated.?..will the indicator shows at the meter panel?..
If it does have it, then you can do the wiring as above. For the indicator, you can shine a flashlight on the panel to see what indicators are there, and if the cruise ones are.
Old 04-08-2010, 10:56 AM   #2
kazama82
Drives: VIOS
hi scott,
i see this post on opening the ECM. If i dc the battery, how do i measure the 12V?
http://www.yarisworld.com/forums/sho...&highlight=ECM
very very sorry for asking a noob question...i have a DVM with me but dunno which wire/connector i need to measure to make sure my car having cruise control function...hope can get some help ...thanks..
kazama82 is offline   Reply With Quote
Old 04-08-2010, 11:15 AM   #3
hi scott,
To take the measurement you would need to do so with the battery still connected and the ignition in the on position. For actually doing the wiring I suggest that people disconnect the battery, while doing so.
You can stick a pin through the rubber plug in that pin location of the ECM connector to take the measurement.
Based on others experience, I don't believe that your car's ECM will have the cruise control functionality.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
