Old 02-07-2010, 02:43 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Thanks for the reply. However, the valving is subjective. It is stiff, yes. However, it's been fine for me.
The problem is, the Megan springs are extremely short in the rear. I doubt I'd find any stand-alone springs that would fit. Then again, I could be 100% wrong. I may just replace them with Tokico HPs and another set of springs.
I didnt mean the dampening rate, i mean the parts used to regulate the valving are inconsistant from one shock to another and tend to leak internally or blow all together. Not trying to be negitive but I see it all the time working where I work. If you called up Megan racing and asked them for a dampening dyno chart they probably would laugh. Between Ksports and Megan racing coil-overs I have seen many issues. With coil-overs you get what you paid for, sure somebody who has a $12k car isnt gonna go out and buy $6000 Penskes or Motons... but still.
Before you spend $ to keep your Megan coil-overs alive consider holding off and saving that $.
But yes, you can replace the front springs easily, rears are not coil over springs but as you said you can easily just put any lowering spring in place of them (meant for that car) and omit the perch.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 02-07-2010, 02:49 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
That's very interesting. Out of curiosity, what do you do that you see this happen often?
As I mentioned, I think I may go for a traditional spring/shock combo, as I never adjust the height or the dampening on the coilovers.
Old 02-07-2010, 03:02 PM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Im a tech at Ptuning so I do installs every day . I don't mean to down play your coil-overs im just trying to give good advise.
A good shock/spring combo should do just fine, Tokicos are good shocks. A proper coil-over will generally out-perform a spring/shock combo on the track but then again it doesnt mean much if some dude with $6000 coil-overs can't drive lol.
Ptuning.com
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Lowering Springs or Coilovers? DJ_Trizzak Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 08-29-2007 03:04 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
