Old 02-08-2010, 02:26 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Originally Posted by Aothachos View Post
so eventually overtime I will have to replace the pulley? Is there a set certain amount of miles that NST recommends to replace it if so? It has been about 25-30 thousand miles since I installed these. I think it is also why my belt is squeaking everytime i start up because it is loose due to friction engraving its place in it lol
Hmm, honestly, I don't know, but then aluminum is lighter and softer than steel, so I wouldn't be surprised at all if it wears off much quicker. Can you really see/feel a groove where the belt sits? If it's just polished shiny I wouldn't worry too much. It would be interested to compare with an older OEM water pulley, see if you get the same wear after a while.
My belt is squeaking too, 1 in 10 starts I'd say, because I couldn't get it as tight as it should be. But I'm working on adapting the Scion xD belt tensioner to the Yaris and if I can make it work, I'll post the DIY
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-08-2010, 02:42 PM   #2
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
no the groove is pretty deep i say about 1-2mm, u can feel the edges perfectly where the belt sits on the pulley
Aothachos is offline   Reply With Quote
