View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 02-03-2010, 12:18 PM   #271
I'm hip!
Old 02-08-2010, 09:07 PM   #272
advocate
Drives: car
God I am waiting for this soooooooooooo bad
Old 02-08-2010, 11:15 PM   #273
I am supposed to receive the first 5 production PCB sets this week. If all is well with them I will let them cut the first production run (100 PCB sets). In the meantime I am working on wrapping up the firmware. I figured out how to get the cluster to tell me the raw reading of the fuel level sender, so the numeric fuel level / range until empty won't require a wire to be tapped. I am now working on getting the ECM to give up the air to fuel ratio.
Old 02-08-2010, 11:55 PM   #274
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
No words:
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-09-2010, 12:30 PM   #275
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Scott, that left side vent mount will be perfect for me, especially in that orange RS glow with black backing...just installed RS trim pieces and a/c heater control knobs as well so black on black match.
Old 02-09-2010, 01:07 PM   #276
My understanding is that he can read memory addresses but would need the machine code to write to the ECM. Reverse engineering the machine code is problematic, and Toyota doesn't share it.
Have I got that right?
Old 02-09-2010, 01:26 PM   #277
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Whenever you start taking orders for this I have my $$ ready for you.
devinlamothe is offline   Reply With Quote
Old 02-09-2010, 01:52 PM   #278
That's correct.
I am making a bit more progress with being able to write to the ECM, for example I figured out the CAN message to make the ECM turn on/off the radiator fan at will.
For the question above about the AFR - The Yaris' O2 sensors are wide band zirconia sensors.
Old 02-09-2010, 03:07 PM   #279
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
i have a feeling this product will never come out, so many requests for more and more things to be adde, LOL I kid i kid.
Check out my Build thread:
Old 02-09-2010, 03:18 PM   #280
In the Engineering world we call it "feature creep". Marketing people love it (not) when we Engineers keep wanting to add just "one more little thing" before release...
Old 02-09-2010, 04:51 PM   #281
^ and building a website for a client is exactly like that too!
Old 02-09-2010, 05:19 PM   #282
POORSHA
POORSHA's Avatar
Drives: 2008 LB
And ordering take out is like that too
POORSHA is offline   Reply With Quote
Old 02-09-2010, 10:53 PM   #283
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The best way to eliminate feature creep would be if the YarGauge were updatable via a serial connection... That would basically allow you to ship now and add features later on.
Then again, that would raise the final price for sure. Which I wouldn't mind doing BTW.
Old 02-09-2010, 11:11 PM   #284
The tricky part to that is that it consists of two separate processors, each of which requires a different interface for programming.
Old 02-09-2010, 11:22 PM   #285
Originally Posted by camelll View Post
That is nice about the 02 sensors. Someone can save a fortune on a good gauge and get their a/f wideband from this product. Can you get oil pressure as well?
Well I am sure if you ever get to a point where you can do fuel maps, you will have a lot of people interested.
Just curious, what do you do? Electrical engineer?
Oil pressure is a funny one - The Yaris simply has a pressure switch that is on if there is oil pressure or off if you don't.
I am an Electrical Engineer,
Old 02-10-2010, 03:02 AM   #286
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Originally Posted by Lewis View Post
image this all started with needing a tachometer!
from tiny acorns grow mighty oaktrees.
I am still sold on it if it has a tach and nothing more......lol......we are very lucky to have someone here to construct something like this and I meen we area lucky.......this is very cool.
Old 02-10-2010, 04:21 AM   #287
Kiz
Kiz's Avatar
Drives: '06 Yaris Hatch and TT 300ZX
I can't wait for version 2 that will have a 4x25 character display and it's own plastic case.
OK wishful thinking... I just want it to match my V2 ECUTalk
I am loving this project but I don't want it to mount in my AC vent or DIN slot.
'06 LB 2NZ-FE w/ NST crank pulley "No RWKW" | '89 2+2 VG30DETT Z32 300ZX "Lots RWKW" ;)
Kiz is offline   Reply With Quote
Old 02-10-2010, 03:11 PM   #288
Tamago
Tamago's Avatar
Drives: UZJ100
i've asked before, i'll ask again..
since this is OBD2 driven, will it work on any other "like coded" OBD2 system? (my MR2) if so i DO WANT ONE
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 11:27 AM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 10:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 12:04 PM
