Old 02-11-2010, 07:21 PM   #1
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Originally Posted by Parmas View Post
What about a Top End build? Is there a secret for the ultimate powerband of a 1NZFE?
Basically, the camshaft that you run depends where the power band will be in the rev range.
Ideally, you choose your camshaft based on the intended purpose of the vehicle and where abouts you want the power band to be in the rev range, then select valve springs (and sometimes valves) to suit, and then size your turbo, intake, exhaust and intercooling system accordingly.
In theory, the design of the 1NZFE does not suit really high revs due to the bore to stroke ratio.
If using stock cams, then the factory redline (or slightly higher if it helps with your gear change points) will suffice.
rob323 is offline   Reply With Quote
1NZFE K1 by Carrillo Rod interest list xBoosted Forced Induction Forum 20 01-20-2009 02:51 PM
EVERYONE PLEASE STAY SAFE! Shroomster Off-topic / Other Cars / Everything else Discussions 5 01-01-2009 05:47 AM
CEL blinking during rev limit hit. ddongbap General Yaris / Vitz Discussion 2 10-01-2007 02:10 AM
Hyper Rev: Vol# 108 Vitz (No. 3) **IN STOCK & READY TO SHIP** KamiSpeed Sponsors Classifieds Area 1 03-03-2007 01:50 PM
