Old 02-12-2010, 02:46 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
With all the cut wiring did you check to make sure there's power going to the IC on the alternator before deeming it a dud? The centre wire should have 12V with the car running. (Black with a red tracer is what I have in my '05 Echo wire diagram. Should be the same in the Yaris I hope.) You can use a cheap steel needle as a back-probe.
Old 02-12-2010, 04:42 PM   #2
Jason@SportsCar
Everything worked fine any time we have started it in the last month.
But we just had the alternator tested, and it checks out. Might be the kill switch. No I get to start chasing wires.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
