![]() Drives: 2007 Yaris Join Date: Feb 2010
Hi Scott, this starter has a couple of connections I couldn't match up using your install guide.
FACTORY ALARM DISARM FACTORY REARM (+) IGNITION OUT (TO ALARM) (-) ACTIVATION INPUT And where is the neutral safety switch connection? Or is that not needed because the motor wont start unless its in park or neutral? Thanks! -Josh |
#2 | |
Does your car have an alarm? If not those are not used, if it does and the alarm is the factory TVIP one, I can point you to those connections. If it is an aftermarket one, then you will have to refer to the documentation for the alarm. A neutral safety switch would be used if you are installing a remote starter on a Yaris with a manual transmission. The Yaris doesn't have one, so as per my guide, you would need to purchase or create one that will work with the Yaris's shift. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
