![]() Drives: 2007 Yaris Join Date: Feb 2010
For the (+) IGNITION OUT (TO ALARM) it says:
As an add-on car starter: If connected, disconnect the ignition/accessory input of the remote controlled security or keyless entry system. Connect the H1/3 YELLOW ignition output to the ignition/accessory input of the remote controlled security or keyless entry system. The wire will prevent the host system from sensing that the ignition is on during remote start operation. Should I use the "Disarm No Unlock use key sense wire" ? That requires a negative input not a positive input like this one outputs. Should I get a relay and wire it that way? Also, the (-) ACTIVATION INPUT, This input comes from the factory set to 1 activation pulse. This means that it is necessary to have 1 ground pulse on the white/blue wire for the remote start to activate or to deactivate. The same holds true for the remote control activation when set to a two pulse setting it is necessary to press the button twice for the remote start to activate or deactivate. I can't quite figure out what that means. Would this input be used if you wanted to use the factory lock button? It has a little diagram about a Momentary switch so I really don't know what its talking about. |
#2 | |
The (-)Activation input is for triggering the remote starter from an existing remote. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
