![]() Drives: 2007 Yaris Join Date: Feb 2010
Hi Scott, it is the factory alarm.
OK. The TVIP OEM Alarm has a 36 pin connector:
TVIP Conn E.jpg Pin 12 (white/light blue wire) goes to a starter cut relay, so you will need to follow that wire to the starter cut relay, and tap the Black Wire coming off of that relay with your start wire. On a non-alarm car that would be the black wires on the ignition switch connector. Pin 9 (orange wire) is the ignition switch power input to the TVIP, so if it actually needs the (+) IGNITION OUT (TO ALARM) connection, that's where it would be done. The key sense wire is the yellow wire on the two pin connector that is near the face of the keyswitch. Last edited by CTScott; 02-14-2010 at 06:03 PM. |
Here's connector D19, which is the key sense connection (2 pin with yellow and white/black wires):
Conn D19 - Key sense.jpg |
#4 | |
![]() Drives: 2010 gray Yaris Join Date: Jan 2015
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
