Old 02-14-2010, 04:30 PM   #1
Originally Posted by jroy View Post
Hi Scott, it is the factory alarm.
OK. The TVIP OEM Alarm has a 36 pin connector:
Pin 12 (white/light blue wire) goes to a starter cut relay, so you will need to follow that wire to the starter cut relay, and tap the Black Wire coming off of that relay with your start wire. On a non-alarm car that would be the black wires on the ignition switch connector.
Pin 9 (orange wire) is the ignition switch power input to the TVIP, so if it actually needs the (+) IGNITION OUT (TO ALARM) connection, that's where it would be done.
The key sense wire is the yellow wire on the two pin connector that is near the face of the keyswitch.
Old 02-14-2010, 04:34 PM   #2
Here's connector D19, which is the key sense connection (2 pin with yellow and white/black wires):
Old 09-27-2015, 06:42 PM   #3
Tanes70
Drives: 2010 gray Yaris
Attachment 31700
Where is this connector located?
Tanes70 is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
