Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Sweet! Thanks for your help Jason
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
Keep in mind none of the tires you were looking at are ST legal - must have a 140 or higher tread wear rating for ST.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
Joey
I guess I'll just have to use the Falkens again for the next event and just grab a sway bar and CAI way before. I can still wait a minute to get rims and tires seeing as how I need to make enough storage space for them anyway. Can I still run the sway bar and CAI in ST? I'm looking at the class rules right now, but doesn't really say anything specific about engine and suspension parts til you get to SP.
http://www.sfrscca.com/solo2/faq/auto.htm#114 I take it "common parts" also include CAI? Or is it limited to a filter-only upgrade? Is sway bar also considered common?
#4 | |
You want to look at section 13-19, specifically for Street Touring.
#5 | |
Joey
#6 | |
ST will let you do a lot of things to make up for the lack of the stock classes sticky tires: CIA, header, cat-back, ECU, pulleys, shifter, suspension, race seats, wings. Just for comparisons sake... We took our stock class RX-8, that had won four strait BS championships and converted it to STX in 2009. The difference in prep between stock and STX was about $10k, and the car was slower in STX trim - it is no longer in STX trim. I like race tires. imho it is hard to beat the transformation that occurs when you put race tires on an otherwise "stock" car. The comfortable daily driver feels like a racecar with just a simple tire change. While an ST car reminds you on a daily basis with its poor ride quality, noisy exhaust and limited ground clearance. And in almost every case a stock class car on race tires is quicker than a no expense spared ST car. Spend more money to go slower? No thanks.
#7 | |
Apexing Egg!!
now what i would REALLY like to do is run an S2k in stock class with R-comp's. THAT would be fuuuun!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
| THE BEST AUDIO SPEAKER | phenoyz77 | In Car Entertainment + Electronics (audio / video / alarm) | 58 | 01-20-2010 10:46 PM |
| FS: Waterloo, ON: 14's and r comps | thebarber | Items for Sale by private party | 7 | 01-21-2009 06:02 PM |
